Author Topic: CB750F2 .... silk purse from a sows ear.  (Read 33053 times)
Offline SumpMagnet
Re: CB750F2 .... silk purse from a sows ear.
« Reply #15 on: July 30, 2018, 10:59:32 PM »
It's a multi stage task....
1) strip and carry through the house to the shed to work on main assemblies.
2) dry build in back garden where it's safe
3) when it's all snag free...break it down for final assembly out front.
I want to be able to work in a safe place e where I can stop for a break and not need to pack everything away. Nasty right turn off the hall prevents a clear run with a complete bike...and not getting a divorce prevents me building it in the hallway 🤔
CB750F2 - in pieces
Offline MCTID
« Reply #16 on: July 31, 2018, 08:27:03 AM »
My Brother in Law built a 26 foot long steel boat in his back garden, then when it was finished he lifted it up and over his Bungalow with a Crane.................just saying.
Offline SumpMagnet
CB750F2 - in pieces
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Offline Moorey
« Reply #19 on: July 31, 2018, 08:52:20 AM »
Leave the complete front end off, remove the rear wheel and stand it up on the swing arm ends on a sack cart or dolly and a couple of you should be able to get it through the house. I've done it many moons ago. But you have plenty off time to think about that one yet.
« Reply #20 on: July 31, 2018, 09:17:48 AM »
Hi. Are you selling off the bits you don't want to help fund it. If you are can I have first dibs on the exhaust headers. I fully restored one of these a few years ago and at 14000  miles the head will be ready for a rebuild, specifically the exhaust valve guides. Sorry to sound mercenary about the exhaust but you have to get in quick on here. Good luck with the build.
Sent from my Nexus 6 using Tapatalk
« Reply #21 on: July 31, 2018, 12:46:01 PM »
Looks like that will keep you off the streets for quite some time, it's good that you are taking lots of photos, I found it handy when reassembling, especially for cable and wiring runs.
Offline SumpMagnet
« Reply #22 on: July 31, 2018, 01:02:02 PM »
With front and back ends off, we just about managed. Made a harness for the front to take the weight, with second person steering from the frame rails at the back. Damned heavy.. my back is aching...but we did it. These things are VERY heavy. Will get a sack truck for next time.
Next job is to get the engine out. I have made a cradle out of scrap wood so I can roll the frame over...and lift it off. Then I have a stretcher frame to move the engine so I can get it in the shed and on the bench. Once I have recovered..
As far as mileage goes...I am pretty sure the Speedo is not original, so I am assuming high mileage...and expecting at least a tip end overhaul. Plus..can gain tensioner, guides etc.
Better that way I think. Pessimists only get nice surprises. Optimists set themselves up for disappointment......
Nice surprise 1...
The forks dropped out if the yokes nice and clean, with no suspicious tight spots. A sign of straightness. Chrome is amazingly good. I have got bikes through MOTs with worse.
Nice surprise 2..
The headstock was nice and tidy with no I ovalling, and the bearings had been greased. And the castle but had never seen a hammer and screwdriver.
Today's odd find.
Something looked to have been welded on the frame behind the tank mounts at some point, either side of the centre top tube. Then removed and painted over. Thought it was damage until I realised it was on both sides and symmetrical. Wonder what was there...
Now...my surplus parts...
I probably will be selling on the bits I don't need to help buy the bits I do. Not immediately, just in case plans change...but as soon as I have a replacement part paid for. But drop me a message on the headers and I will give you first refusal when  I sell. Going to cut off the remnant of tail pipe as the clamp is messed up and give the chrome a clean so I can check condition.
Not sure yet on the headlamp brackets. The clamps on the ones I have are good...and I have some scrap 4mm ally plate (6061 I think) so might make my own. Depends if I can find an original headlamp assembly.
This afternoon's job is to make a bearing retainer tool ....
CB750F2 - in pieces
« Reply #23 on: July 31, 2018, 01:09:50 PM »
Going great guns, well done. False economy and bad practice just hoping to do a top end rebuild. There are rubber seals and O rings that will be perished in the bottom end and it is a bit fool hardy not changing the primary chains whilst the engine is out. You could start it up after a top end overhaul and the bottom end could most probably be clanking away (more than they do at the best of times) and you would need to take engine out again.
Offline SumpMagnet
« Reply #24 on: July 31, 2018, 02:55:46 PM »
Good point and noted about the primary chain and tensioner. I'm more used to Hy-Vo types that last forever, and this is a roller one. Added to the list of things.
So it's strip down the top and both sides, flip it over and split the cases. Check gearbox bearings, shafts, gears, selectors. Check the state of the crank, replace the primary chain and tensioner, sort the camchain and tensioner/guides. Gearbox output bearing and seal will probably get swapped as well. Exhaust valve guides, find at least 3 more exhaust collets, add in a full gasket set....and replace anything worn out or broken. Which will probably include me by then :)
meanwhile....the shelving set aside for bits in the shed is filling up nicely...
All the smaller bits are labelled, fasteners replaced in situ, and boxed or bagged up
The frame and engine are in the back garden safely wrapped up while I tidy up and get ready for the next stage. I even had time to relax and experience the joys of the laid back easy rider bars this thing arrived with.....
you didn't think I was going to put  them on a bike!!!
While I try to figure out what might have been attached here....
Weld scar on the first layer of bracing....at the corner of the second. There is an identical one on the other side.
I also need to work out how to strip and paint the frame without losing the rivetted on ID plate. Sure, there is a seperate stamped number, but I would really like to retain it.
CB750F2 - in pieces
« Reply #25 on: July 31, 2018, 03:06:47 PM »
The frame looks standard to me, no extra bits and no bits missing either.
« Reply #26 on: July 31, 2018, 03:08:51 PM »
The weld scar is just a weld through point to the underlying tube of main frame.
It's to raise the torsional rigidity of that top tube going into the headstock or else the pressing could to rotate around the tube. Also distributes the weld loading further along the tube from that seam weld to assist in avoiding a stress fracture at the seam point.
They'd have had two holes there in production so that they can build weld up on the base tube within the hole and then fix it to the perimeter of the outer pressing.
I think.
Offline SumpMagnet
« Reply #27 on: July 31, 2018, 03:48:40 PM »
Thanks ...you lot know EVERYTHING!
Nice to know this sort of thing, as I want to learn all I can about the beast as I go, good and bad, and ugly. I would be tempted to break out hte grinding pad and remove it...but now I won't. It's supposed to be there....so there it will stay :)
CB750F2 - in pieces
« Reply #28 on: July 31, 2018, 04:04:47 PM »
Gearbox bearings rarely need replacing unless allowed to go rusty and several are Honda only (expensive) due to grooves on the outer, rest is just time, care and super cleanliness
Offline petermigreen
« Reply #29 on: July 31, 2018, 06:53:50 PM »
There are two ways to retain the vin plate. You could mask it off or ask your powder coater/painter to mask it off but mine won't do it.
or you can carefully remove the rivets and replace the plate after painting. I used these
https://www.oneillvintageford.co.uk/cgi-bin/sh000001.cgi?REFPAGE=https%3a%2f%2fwww%2eoneillvintageford%2eco%2euk%2f&WD=rivet&PN=Ford_Model_A_Dash_Plates%2ehtml%23a_23100#a_23100
Probably available elsewhere also but haven't been able to find them.
Select suitable size rivets from the pack and measure diameter then find a drill bit a shade smaller and they tap in quite easily.
BUT.
If you need to get registered in the UK make sure you take a photo of the vin plate BEFORE you remove it for evidence. I nearly came unstuck with my CB400F restoration because the dating officer said it showed evidence of tampering which technically it had as I'd removed it and replaced it but on the same bike so no shenanigans  ;D
« Last Edit: July 31, 2018, 06:56:28 PM by petermigreen »
