Author Topic: Running On Two Cylinders  (Read 716 times)
Offline adespin
« on: August 02, 2018, 06:50:56 PM »
I recently rebuilt the carbs on the K1 including setting the float hights, but couldn't run the bike untill the exhaust fiasco with David Silver was sorted out. Now after fitting a new set from CMS which fitted great, i took it for a ride, ten minutes into the ride it started to misfire running on two cylinders, managed to get it back home which was not easy in hilly Wales. Touching the silencers revealed that it was only running on 1 & 2, while rebuilding the carbs i replaced the fuel pipes from carbs to petrol tap as the old pipes were crumbling at the tap ends and leaking. The new pipes i got off ebay which were 5mm bore thin walled. What i discovered was one pipe feeding cylinders 3 & 4 had kinked on the bend close to the tap stopping the flow.
  So i can't rely on this fuel pipe from ebay. where do you guys and gals  get your fuel line from, and would you use 5mm or 6mm.
« Last Edit: August 02, 2018, 07:04:49 PM by adespin »
1971 cb750 K1
Online Johnwebley
Re: Running On Two Cylinders
« Reply #1 on: August 02, 2018, 07:05:46 PM »
I use 5mm smooth .available on Ebay. But not thin wall.sorry can't find link.
Is it nitrile. Try a search
Offline adespin
« Reply #2 on: August 02, 2018, 07:49:19 PM »
Anybody got any links on ebay.
1971 cb750 K1
Online Nurse Julie
« Reply #3 on: August 02, 2018, 08:02:21 PM »
Trig will be in soon, I will get him to let you know where he gets his stock from.
Offline RGP750
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline adespin
« Reply #6 on: August 02, 2018, 11:32:37 PM »
   Thanks All :)
« Last Edit: August 02, 2018, 11:36:01 PM by adespin »
1971 cb750 K1
