Author Topic: how do I fit a black metal number plate to my motorcycle?  (Read 2378 times)
Offline Athame57
    • SeaWitch Artist
« on: August 08, 2018, 01:29:33 PM »
I just got a black metal number plate through the post for my CB400F2 and stuff the law lol. But it's got no fittings, is this going to be difficult or is there an easy way? My bike is at this time in a workshop having things done...
1978 CB400F2 called Elen.
Re: how do I fit a black metal number plate to my motorcycle?
« Reply #1 on: August 08, 2018, 02:08:09 PM »
Pop rivett it on but put a couple of foam pads behind it to stop it rattling.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #2 on: August 08, 2018, 02:13:15 PM »
Unless it’s a very late registered one, it should now be legal anyway if it’s Historic class.  If you have the original plate and it was fitted on the same holder then you could use that as a template and drill through into you new plate.  As Julie says you could pop rivet it on but I personally prefer to use small Phillips head machine screws with nylon nuts in stainless.
Ian
Offline RGP750
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline Green1
« Reply #5 on: August 08, 2018, 06:33:54 PM »
You could always bend the plate to suite  ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Moorey
« Reply #6 on: August 08, 2018, 07:29:15 PM »
More likely the plate will not be flat after coming through the post. Mine had a 3inch roll diagonally on it. it looked like it had been through a set of rollers.
Offline Athame57
    • SeaWitch Artist
« Reply #7 on: August 08, 2018, 08:08:58 PM »
Moorey...it arrived flat as a centre line pigeon and in one piece!
« Reply #8 on: August 08, 2018, 10:33:41 PM »
Use black pop rivets and sticky pads  ;)
Offline Arch stanton
« Reply #9 on: August 08, 2018, 10:43:17 PM »
 Why would a black plate be any different to fit
Than a yellow plate?
« Reply #10 on: August 09, 2018, 07:03:55 AM »
I assume that it’s a pressed aluminium one instead of a plastic one?
2022 Tiger Sport 660
« Reply #11 on: August 09, 2018, 07:57:20 AM »
What is wrong with black plastic nuts and bolts, or white if the hole is in a number/letter.
NOTE it is now an MOT failure(and as such a Plod excuse to stop even if no MOT required) for the fixing bolts to alter the appearance of the letters/numbers
Offline RGP750
« Reply #12 on: August 09, 2018, 08:55:11 AM »
The double sided is more and adequate to keep it on you don't need any bolts or rivets.
Most modern cars use only this stuff,and you try getting a cracked front one off to replace it .
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #13 on: August 09, 2018, 12:38:34 PM »
I see a lot of cars with no rear number plate, just some sticky pads left doing nothing! They probably didn't clean the surfaces and fit them properly, but I will 'stick' to using screws and nuts on mine.  :)
Offline Green1
« Reply #14 on: August 09, 2018, 08:50:17 PM »
The sticky pads you see are nothing like the trim tape that RGP has highlighted if stuck properly the number plate will snap before becoming unstuck
Saying that I still bolted mine because I didn't even think about sticking it.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
