Author Topic: CB 750 F2 Rear lower mount bolt  (Read 515 times)
Offline Moxey
« on: August 09, 2018, 09:54:40 AM »
Morning
A little while ago I bought some stainless mount bolts for my 750f2 (one of mine was a little bent and the threads were a bit suspect, also I am a bit of a tart ;D).
The kit I purchased was from Zedparts, of the 3 mounting bolts 2 were fine but the rear lower engine mount (12mm) which goes through the footpegs is considerably shorter (50mm or so).
Now I've mentioned this to the seller on the presumption they sent the wrong bolt and they say they have never cut a bolt this long for a 750 SOHC K or F so I'm wondering is this the original bolt?
78 CB 750 F2
77 CG 125
97 VFR 750
Online Bryanj
Re: CB 750 F2 Rear lower mount bolt
« Reply #1 on: August 10, 2018, 07:24:00 AM »
From memory the F2 has a longer bolt as it goes through the two alloy footrest plates, try comparing part numbers on CMSNL
