Author Topic: remove rust from tank  (Read 995 times)
Offline mickwinf
« on: August 13, 2018, 09:35:04 PM »
I have cleaned my 550 tank and used some rust remover which worked fine. The problem is how do i stop it flash rusting as it has to be rinsed out with water so rust forms straight away. Any scientists out there know what i should do?
Offline Underdog1
Re: remove rust from tank
« Reply #1 on: August 13, 2018, 09:48:13 PM »
Phosphoric acid based rust removers don’t need to be rinsed out with water, just pour any excess out and then rinse out with a bit of fuel. Diesel will leave an oily residue which will cost the inside nicely but petrol will do if it’s going to be used straight away
Offline jon stead
« Reply #2 on: August 14, 2018, 05:46:55 AM »
I used the method in the link below, to clean my tank a few years ago now. So far, so good.
http://www.realclassic.co.uk/techfiles/petrol_tank_cleaning_and_rust_removal.html6
« Last Edit: August 14, 2018, 05:49:53 AM by jon stead »
Offline mickwinf
« Reply #3 on: August 14, 2018, 11:42:14 PM »
ok so i tried again using the neat product then rinsed out with petrol, so will see how it goes.
