Author Topic: Bouncy Forks  (Read 2563 times)
Offline adespin
Bouncy Forks
« on: August 21, 2018, 05:14:32 PM »
I've no doubt that this has been asked many times before, so i apologize in advance for asking. My 71 K1 750 has a horrible ride on the front end, the forks follow every large or small undulations in the road, only hitting a pothole do i get any fork action.
  When moving the forks up and down on standstill they seem to work fine, it's putting me off going out for a ride. :'( :'(
1971 cb750 K1
Re: Bouncy Forks
« Reply #1 on: August 21, 2018, 05:33:22 PM »
Check fork oil
You may have to much or to thick.try altering tyre pressure up or down a few Psi
Re: Bouncy Forks
« Reply #2 on: August 21, 2018, 05:56:20 PM »
As John says, tyre pressure and also the type / make of tyre can make a huge difference. Also consider overhauling the forks if the basics don't make it any better. Maybe too little or too much oil, or knackered oil.
Re: Bouncy Forks
« Reply #3 on: August 21, 2018, 08:08:29 PM »
Maybe its just a case of getting used to it... these old bikes have big heavy wheels and slighty cruder suspension than the modern stuff.... mine is also a little less smooth over rough surfaces than my more modern stuff but the forks have been stripped, serviced and have the correct amount of fresh oil and they work fine when being compressed... so I think it may be just something to get on with.
« Last Edit: August 21, 2018, 10:45:39 PM by Rob62 »
Re: Bouncy Forks
« Reply #4 on: August 21, 2018, 10:25:34 PM »
Make sure no one has put washers/spacers on top of the springs  ;)
Offline adespin
Re: Bouncy Forks
« Reply #5 on: August 22, 2018, 10:13:35 AM »
Trigger what would be the reason for adding spacers on top of the springs ?
The previous owner supposedly gave the bike a full service including new fork seals and oil before selling it to me, so i will try changing the oil to 5w.
1971 cb750 K1
Re: Bouncy Forks
« Reply #6 on: August 22, 2018, 11:49:53 AM »
  try ATF oil
Offline adespin
Re: Bouncy Forks
« Reply #7 on: August 22, 2018, 11:54:05 AM »
Is that what you use John ?
1971 cb750 K1
Re: Bouncy Forks
« Reply #8 on: August 22, 2018, 12:08:10 PM »
It's what Honda recommend!
Re: Bouncy Forks
« Reply #9 on: August 22, 2018, 12:29:12 PM »
Offline SumpMagnet
Re: Bouncy Forks
« Reply #10 on: August 22, 2018, 02:15:56 PM »
Adding spacers to teh top of the forks is an old-school way of stiffening up the springs. You are basically preloading the spring. It has a side effect of reducing the travel leading to some interesting effects under load and bottoming out if you hit a bump on the brakes.
The bodgers way could involve stacks of 2p coins.....which gave you a regular size and was...well...cheaper than buying big washers! I found that one first when I unscrewed a top cap and got a surprise shower of small change.
CB750F2 - in pieces
Offline adespin
Re: Bouncy Forks
« Reply #11 on: August 22, 2018, 02:50:30 PM »
The mind boggles :o
1971 cb750 K1
Offline Moorey
Re: Bouncy Forks
« Reply #12 on: August 22, 2018, 04:35:11 PM »
A frequently done misconception.
All adding spacers does is limit the amount of travel in a spring. It doesn't stiffen springs at all. The spring rate is the spring rate no matter how many spacers are put in.
Do not confuse a springs, spring rate with a springs, load/design rate.
Offline SumpMagnet
Re: Bouncy Forks
« Reply #13 on: August 23, 2018, 09:42:16 AM »
I think what was really going on was taking up the slack on worn out springs that had a permanent set. Put the springs under load and the bike would sit higher and appear stiffer.
Then you go for a ride and convince
CB750F2 - in pieces
Offline Paulreade
  • SOHC newcomer
  • Carpe diem
Re: Bouncy Forks
« Reply #14 on: August 31, 2018, 07:00:51 PM »
Are your wheels correctly trued and balanced ?. My front wheel was not fully trued, it had a flat spot , I  have improved it but it needs another go, as does the rear wheel. Making a slight improvement on the front made a slight diffence to the bounce I was experiencing although I still need to properly true them both. I have also picked up some 5w oil which I will add to improve the damping. Like you it puts me off riding the Honda a little, but with some patience I suspect it will get sorted.
Suzuki GSX 1250 FA
Triumph t100 bonneville
Honda cb750 k6
