Author Topic: ignition switch wiring CB750K7  (Read 1383 times)
Offline tangerine
« on: August 28, 2018, 05:37:57 PM »
I am re-instating the wiring into a new standard ignition switch. The connector on the loom was removed years ago ( after an attempted theft). I need to know which coloured wire goes where on the connector block. Any help gratefully received.
Offline petermigreen
Re: ignition switch wiring CB750K7
« Reply #1 on: August 28, 2018, 06:51:54 PM »
K7 wiring diagram should help
Offline tangerine
« Reply #2 on: August 28, 2018, 07:26:25 PM »
Thanks for the diagram. I have identified the wires to go in the connector. It's now which wire goes in which position to connect to the correct spade connector on the ignition switch side.
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #3 on: August 28, 2018, 08:04:15 PM »
Unfortunately, the diagrams do not  give the orientation and type of connector.
Image attached of a K7 ignition OE connector, rear view
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline tangerine
« Reply #4 on: August 28, 2018, 11:31:14 PM »
that looks like a great deal of help. Thanks BigAl
