Author Topic: Cylinder one running cooler than other three  (Read 642 times)
Offline billywingnut
« on: September 11, 2018, 08:15:31 PM »
Having restored my bike and done around 300 miles I notice cyl. one runs cooler from cold start, when hot it's difficult to tell. The carbs all had new DS kits fitted and I balanced carbs twice. The valves were lapped and new rings fitted, new plugs and plug tops. bike now has 34000 on it. No smoke and it pulls well. I have done valves to 3 thou for the hot summer. I thought I knew the answers to most things but not so sure now.  Before I start ripping things apart again I would appreciate your views.
Offline petermigreen
« Reply #1 on: September 11, 2018, 08:32:15 PM »
As cylinders 1&4 share coils/points probably safe to eliminate those.
New plugs aren’t guaranteed good though. I’d try swapping plug with another cylinder first to eliminate or prove plug In number one is all good. Also double check lead/cap.
Peter
« Last Edit: September 11, 2018, 08:34:14 PM by petermigreen »
Re: Cylinder one running cooler than other three
« Reply #2 on: September 11, 2018, 09:17:58 PM »
Could it be a case of No 1 cylinder is running at the correct temperature and 2,3 and 4 are running very hot?
« Reply #3 on: September 11, 2018, 09:37:07 PM »
Compression test?
Offline Tomb
« Reply #4 on: September 12, 2018, 07:21:57 AM »
what he^ said
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
« Reply #5 on: September 12, 2018, 09:44:10 AM »
To add to the considered list,  you could try warming it and then individually turning the pilot/idle circuit screws to judge if you've got the same response to each carb.
If you get very different or no change from one carb it would suggest that idle circuit to be impaired and maybe affecting the low response mixture.
