Author Topic: Squeaking front brake  (Read 2953 times)
Offline Athame57
    • SeaWitch Artist
« on: September 22, 2018, 10:47:57 AM »
My front brake is capable of squeaking loud enough to have people looking at me funny sometimes, I bet I'm not going to oil them but what can I do, why does this happen if it's not at the disc?
1978 CB400F2 called Elen.
Re: Squeaking front brake
« Reply #1 on: September 22, 2018, 10:55:21 AM »
CB400/4's are renown for having squeaky front brakes. Some things to check....are the pads glazed, if so, deglaze. Is the floating caliper adjusted correctly giving the correct clearance, if not re adjust. Is the disc warped, if so, get skimmed.
I spent 4 years trying to sort the problem on mine and finally had the disc skimmed which sorted it for about 4 months but it has just started again, albeit intermittently, but that is probably glazed pads this time.
« Reply #2 on: September 22, 2018, 12:23:09 PM »
Which brake pads are you using?
Are they sintered or non sintered?
Offline Skunky
« Reply #3 on: September 22, 2018, 02:52:27 PM »
Hi - The old remedy for squeaky brakes is to put a light coating of high temperature grease on the metal back of the pad. Copper grease should do the job. Remember kids not on the front.
Honda CB400F USA
Triumph Thruxton 900
BMW K100 Custom Buils
« Reply #4 on: September 22, 2018, 03:18:33 PM »
Yep, I tried that too, made no difference at all.
Offline Skunky
« Reply #5 on: September 22, 2018, 04:50:02 PM »
Well at least if you hear the screech you know you’re brakes are working  ;D
Honda CB400F USA
Offline Skunky
« Reply #6 on: September 22, 2018, 04:51:39 PM »
Are you allowed to make noise in the sleepy hamlet of Horncastle Julie
« Last Edit: September 22, 2018, 04:53:34 PM by Skunky »
Honda CB400F USA
« Reply #7 on: September 22, 2018, 05:20:25 PM »
Oh yes, and I do quite often  ;D ;D. Luckily we actually live in an even sleepier hamlet a few miles outside Horncastle and the Natives are mainly old and deaf, so no problems there either  :).
Offline Skunky
« Reply #8 on: September 22, 2018, 05:25:02 PM »
Spent a lot of Time in Roughton so I know what you mean  ;D
Honda CB400F USA
« Reply #9 on: September 22, 2018, 05:54:21 PM »
Mareham le Fen, where we live, is a City compared to Roughton !!!
« Reply #10 on: September 22, 2018, 09:11:43 PM »
If anybody can remember the Citroen GS the manufactures idea to stop squeaky brakes was to put two finger lines of Copperslip on either side of the DISC!!!! and yes it worked but they had the high pressure breaking system worked off the suspension. Apparently it stopped the dust collecting in the pad crevasses.
PLEASE NOTE I am NOT recommending this just recounting and old manufactures fix
Offline flatfour
« Reply #11 on: September 23, 2018, 09:49:32 AM »
Since returning from a fairly lengthy visit to Japan last week, the front brakes are squeaking heavily on both bikes. They were not too bad before being parked up, the discs rotate freely enough so I assume it must be down to the change in temperature (it was in the 30's when I went)?
Offline florence
« Reply #12 on: September 23, 2018, 04:45:07 PM »
The brake on mine has always been noisy, i.e. in the last 23 years of use.  It seems that when the caliper is adjusted correctly and the brake is at it's best, it squeaks the most.  Turning kinetic energy into sound waves is how these things stop  :)
« Reply #13 on: September 23, 2018, 05:37:49 PM »
Isn't that what a band does Steve?
2022 Tiger Sport 660
Offline Athame57
    • SeaWitch Artist
« Reply #14 on: October 16, 2018, 05:36:10 PM »
Just had the froont brake apart. Put some silicone lube behind the discs and set the fixed caliper at 0.16 ...still it squeaks!
