Author Topic: spark plug screwed up / problem  (Read 3308 times)
Offline saxby
« on: March 09, 2008, 03:17:39 PM »
have had the bike running on all 4 cylinders after  i got it . but  no on the re build i can see a problem ...
the spark plug in the first cylinder is in at a slight angle and not screwed in all the way .. i take it out and can see its been put in at a fu**ed up angle . and has crossed the threads . it was only in about 25% of the threading on the spark plug .. i have  tryed to screw it back in on what looks straight tightening up a half turn and a quarter back trying to bore back on the original threads .its as tight as i dare go. but only in about 60% - 70% still .. and my worry is that small alloy filings are now siting in the cylinder  ...
any ideas ?
*should i just keep an eye out on ebay for a top end ,and do a top end re build?
* or just fire it up and ignore it
Re: spark plug screwed up / problem
« Reply #1 on: March 09, 2008, 04:00:12 PM »
If the spark plug has been x-threaded, there's no alternative to a helicoil I'm afraid. The internal pressure will blow out any bodged fitting (and you may be correct about swarf in the cylinder).
So, head off I'm afraid.
You can try a used one but how can you be sure that what you're getting is going to be any good?
Best bet is a local breaker or someone on here who has a spare head.
GeoffT in the Orkneys was looking for a 550 head recently. I have a complete 550 engine but shipping it up there would be prohibitive.
2022 Tiger Sport 660
Offline saxby
« Reply #2 on: March 11, 2008, 12:44:03 AM »
seen one on ebay item no    110231895640
 says it needs work but will cost 20 inc shiping
dont realy know about this sort of thing ..
dont know what a helicoil is . im guesing that i will need to take it in some were ..
as for your engine . i live in cardiff at the moment . but do trips back home to hull and manchester a lot . the bike is never going to be a show winner and has been altered in a lot of ways  so i am looking at the cheapest option ..
« Reply #3 on: March 11, 2008, 07:38:15 AM »
I've been talking to the guy on eBay. He's in S Wales. I wanted some gearbox bits but the postage was just too much (
« Reply #4 on: March 11, 2008, 07:39:15 AM »
A helicoil is a threaded insert. It has to be done by an engineering company but is the only way to fix buggered threads on spark plugs.
Offline saxby
« Reply #5 on: March 11, 2008, 06:55:20 PM »
 thought about it over night . and i had anouthere go at trying to re bore the threads the right way.
as long as i didnt lock the spark plug in there  i had nothing to louse as  the outhere 2 options were to get a new head or  send it away ..
after takeing my time back and forth using oil and  cleaning the plug and the hole up i have it all the way in and squire . my onley woury is that the  tiney aloy bits in there might do some damage . im hopeing that when i fire it up they will just get spat out  and not damage any thing . what do you think.?
Offline matthewmosse
« Reply #6 on: March 11, 2008, 07:01:52 PM »
Had a friend with the same problem, He used a vacume cleaner to suck out any bits before giving his luck a go. I think it paid off.
Good luck!
