Author Topic: CB500K1 brake bleeding question  (Read 695 times)
Offline AndyH
  • I'm privileged to be a
« on: October 12, 2018, 10:25:20 AM »
Quick Q:  when bleeding the front brake, do I need to put the rubber diaphragm back in along with the cap, each time I squeeze the lever? TIA
Andy
1971 CB750K1
1972 CB500 Four K1 (SOLD)
1978 Suzuki GS750E
Previously....
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Re: CB500K1 brake bleeding question
« Reply #1 on: October 12, 2018, 10:35:28 AM »
No.but be careful that the spurt doesn't splash on paintwork
Offline AndyH
« Reply #2 on: October 12, 2018, 11:06:09 AM »
Yep, that was my worry John.
Andy
1971 CB750K1
1978 Suzuki GS750E
Previously....
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #3 on: October 12, 2018, 11:33:04 AM »
Remove the tank is the safest option!
« Reply #4 on: October 12, 2018, 01:05:04 PM »
If it "spurts" alot it would indicate that the primary seal is not in good condition.
As you move the lever initially, it should firstly close off the route to the reservoir and so direct the fluid down line to the caliper.
If this first action is slow or impaired,  then the fluid starts to come back into the reservoir, giving the spurt. Also, a longer lever travel in use.
Severe wear of this makes it difficult to bleed the system as well.
« Reply #5 on: October 12, 2018, 02:56:04 PM »
But you also get a spurt when you release the lever and pressure is released via the tiny hole
Offline AndyH
« Reply #6 on: October 18, 2018, 04:16:54 AM »
Thanks all for the comments/advice.  All done, and no spurt spillage!! ;D
Andy
1971 CB750K1
1978 Suzuki GS750E
Previously....
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
