Author Topic: Carburettor Insulators  (Read 2877 times)
Offline Deano400
« on: October 24, 2018, 08:33:02 PM »
Can anyone enlighten me as to what the divots are for in two of the carburettor insulators?
Offline Athame57
    • SeaWitch Artist
Re: Carburettor Insulators
« Reply #1 on: October 24, 2018, 08:38:01 PM »
They look to me as something to ease handling, hold between finger and thumb? :-\
1978 CB400F2 called Elen.
Offline Deano400
« Reply #2 on: October 24, 2018, 08:39:28 PM »
Thing is only two out of the four have them. They are listed under different part numbers.
« Reply #3 on: October 24, 2018, 10:00:51 PM »
What part is that ?, I cant even work out where it fits on the carbs  ;D
Davelu88
« Reply #4 on: October 24, 2018, 10:35:01 PM »
They look like inlet manifold rubber ( carb to cylinder head) ;D
« Reply #5 on: October 24, 2018, 10:43:27 PM »
Ah yes Dave, I can see that now 🙄🙄🙄. Off the top of my head and without looking at mine, I don't know why 2 have those flat spots but I do know that the 2 outers are different than the 2 inner ones, slightly different angle and length if I remember correctly.
Davelu88
« Reply #6 on: October 24, 2018, 10:52:28 PM »
I cant remember what 2 are outer and what 2 are inner as mine are off bike  :-[
« Reply #7 on: October 24, 2018, 10:56:33 PM »
Mine are on the bike so I will look in the morning and report back.
« Reply #8 on: October 24, 2018, 11:39:54 PM »
If you look carefully, there are numbers on them. 👍
Offline Athame57
    • SeaWitch Artist
« Reply #9 on: October 25, 2018, 04:11:53 AM »
What if I can't see the numbers?
« Reply #10 on: October 25, 2018, 09:48:59 AM »
The numbers are raised and are on the edge of the rubber where the butt up against the carbs. So in other words you'll need a giraffe's neck to see them and the carbs are also likely to block any view.
I fitted a new set to my 400/4 bought from DS. I didn't see markings when originally installing them and it was only after struggling to fit the carb bank when I looked again and noticed the faint, raised numbers. I think they were numbered 1 to 4.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #11 on: October 25, 2018, 10:14:54 AM »
All 4 of mine have a flat spot on both top and bottom, simple when you think about it, you wouldn't be able to get the screws in there if the flat spot wasn't there. No idea if mine have numbers, eyes not that good 😀😀😀
« Last Edit: October 25, 2018, 10:17:35 AM by Nurse Julie »
Offline Athame57
    • SeaWitch Artist
« Reply #12 on: October 25, 2018, 10:36:10 AM »
(Attachment Link)
Surely you don't (or didn't) drive a Cortina?
« Reply #13 on: October 25, 2018, 10:39:53 AM »
(Attachment Link)
« Reply #14 on: October 25, 2018, 10:49:19 AM »
I've just had a rummage through my old parts box and found the insulators. Apologies for the poor photo but the camera wouldn't focus..... Anyway, the number is on the insulator to the right of the fixing hole. They are numbered 1-4. I assume they are fitted with the number at the top. This will mean you cannot see numbers 1&2 as they will be obscured but you should see 3&4 as they will be on right hand side of the mounting set screw.
1976 Honda 400/4
