Author Topic: washer for oil drain plug.  (Read 748 times)
Offline ricardo
« on: October 30, 2018, 02:04:08 PM »
Hi I've just taken delivery of one of these. It's aluminium!! Is that right? I expected rubber. It came from David Silver
Re: washer for oil drain plug.
« Reply #1 on: October 30, 2018, 02:07:04 PM »
Yes, it is a alloy crush washer. I have to buy them in trade in packs of 100  :o
Offline ricardo
« Reply #2 on: October 30, 2018, 02:14:36 PM »
Thanks Trigger.
It has to be quite firmly bolted down then?
« Reply #3 on: October 30, 2018, 02:57:24 PM »
Yes, 25 ftlb torque, much more than this could crack the sump pan  :o
Offline ricardo
« Reply #4 on: October 30, 2018, 03:42:39 PM »
Ok thanks. Don't have a torque spanner but I'll tighten it gently and if oil seeps i'l give it a little more.
Cheers Ricardo
Offline gtmdriver
« Reply #5 on: October 30, 2018, 06:10:02 PM »
I have moved over to using Dowty Washers for the drain plugs of all my vehicles.
They have a bonded in rubber seal for extra security.
https://www.ebay.co.uk/itm/M10-Metric-Dowty-Washer-Bonded-Seal-2-Pack-/171348552254
« Reply #6 on: October 30, 2018, 06:54:30 PM »
Cheers Ricardo
Not tight enough and it will fall out, too tight and it will crack the sump pan  ;)
Offline ricardo
« Reply #7 on: October 30, 2018, 07:07:27 PM »
wise words from you all
regards
Ricardo
Online SumpMagnet
« Reply #8 on: October 30, 2018, 11:22:46 PM »
It is well worth investing in a torque wrench! I would not be without one.
CB750F2 - in pieces
Offline Maxcaddy (Nighthawk)
« Reply #9 on: October 30, 2018, 11:30:23 PM »
Buy a 1/4" drive low reading one. The usual 1/2" drives are only good for torquing up car wheels.  8)
