Interested in the down pipes. Could you put some pictures up ?
Quote from: Trigger on February 18, 2019, 02:24:27 PMInterested in the down pipes. Could you put some pictures up ?Sure Trigger, it will be a little while as my mate is away now and I don't have access to the garage.
No worries, i can wait a little while
Fully weld up your seams on the seat and then use a flap disc to remove excess weld. You will end up with a much nicer finish in the long run even if you are having a padded finish and you will find it far more satisfying. Not the best way to learn to weld is on your workpiece, practice, practice, practice on bits of scrap and offcuts first.
Quote from: Moorey on September 30, 2019, 12:53:51 PMFully weld up your seams on the seat and then use a flap disc to remove excess weld. You will end up with a much nicer finish in the long run even if you are having a padded finish and you will find it far more satisfying. Not the best way to learn to weld is on your workpiece, practice, practice, practice on bits of scrap and offcuts first.Thanks Chris, I was wondering if I should do that. I sent some pictures to the guy who's going to do the paint and he said to leave it.. but I think I'll take your advice and do that before giving it to him. This is kind of what I'm going for if you hadn't gathered. Watching the few videos of dustin making these seats I wasn't sure if he welded the seams or not. (Attachment Link)
Didn't spot this before but is the grabrail still available, need to see if it differs from what I have now and suspect it does.
