Author Topic: Help required. Regarding 750k1 electrics.  (Read 404 times)
Offline Arch stanton
« on: December 18, 2018, 12:48:26 PM »
Hello folks.
I am building a 750k1 almost from scratch. So I have no points of reference to work from.
What I need is a photo of the electrical department ie, under
The lh side panel.
Also where does the green earth lead connect to the frame?
I'm using a new wiring harness, which has a red wire with a male connector. I suspect that is for a fuse. But where should the other end of the fuse connect?
Any help & advice will be greatly appreciated.
Regards.
Sean.
Re: Help required. Regarding 750k1 electrics.
« Reply #1 on: December 18, 2018, 01:51:44 PM »
Hello folks.
The lh side panel.
Regards.
Sean.
Sean if you look on the project board section there is my new K1 project you will find some pictures in there.  The other side goes to the battery via the lead which connects the battery to the solenoid.this also has a short red wire attached.
Sent from my SM-J330FN using Tapatalk
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #2 on: December 18, 2018, 04:00:48 PM »
Cheers Paul.
Some fine work gone on there.
The thing is. I'm using Electrex World reg/rec.
So that looks like the green, grey & black wires will be obsolete. Maybe?
I need to get a fuse box.
Where does the green with the ring connector go?
I find there is a lot of differences between the K & the F1 which I am more used to.
I see your bike had Cambray wheels. I have a pair for a F1 up the attic.
Thanks for your help. I fear you may hear from me again.
Regards.
Sean.
