Author Topic: Starter solenoid  (Read 753 times)
Offline peterengland
Starter solenoid
« on: December 18, 2018, 01:51:30 PM »
Has just started to click when the starter button is operated, will work fine after a few prods at the starter but not every time. Have removed the solenoid and cleaned all the contacts and connections there are. As the solenoid clicks then is the likelihood of that being the source of the problem rather then further up the line? any help would be appreciated.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Re: Starter solenoid
« Reply #1 on: December 18, 2018, 01:58:10 PM »
Basic questions. What's the state of the battery?
Try charging it up.And see what happens.
Sorry if it's teaching granny to suck eggs
« Reply #2 on: December 18, 2018, 01:59:26 PM »
Check the heavy earth cable form the battery to the frame. Make sure terminals are clean, and the frame is clean/free of paint etc where the earth cable attaches. Try using a large screwdriver and shorting the big terminals on the solenoid across, the starter should spin even with the ignition off. If the starter seems slow or reluctant, could be a battery on it's way out, or starter brushes need cleaning/replacing
« Reply #3 on: December 18, 2018, 06:31:28 PM »
battery good, just over 12v across it, likewise earth. Will try crossing solenoid terminals tomorrow
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #4 on: December 18, 2018, 08:12:56 PM »
Peter, I don't know how you measured, but realise that a battery in rest that reads 12V, is about 80% depleted. I suggest to charge the battery, leave it alone for a couple of hours. Then, after some hours, battery should show 12,6 V or more. If lower there's a good chance the battery has reached the end of its lifetime. Another simple test is to measure voltage over the terminals whilst electric cranking. When voltage dips below 9,5, battery is no longer good.
« Reply #5 on: December 19, 2018, 12:06:35 PM »
Battery fine and 12.7 v across it and cranks like a dream when it engages. Cleaned earth connection and works ok now but occasionally the solenoid will click, however when I cross the terminals it works and spins the starter every time without fail, so to me this points at an intermittent problem with the solenoid?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #6 on: December 19, 2018, 12:33:29 PM »
Or possibly dirty contacts in the wiring to/from or the actual start button itself.
« Reply #7 on: December 19, 2018, 12:35:25 PM »
It may be the start switch that's at fault.  Connect the yellow/red directly to the battery + and see if that improves.
« Reply #8 on: December 19, 2018, 01:09:15 PM »
can it be the start switch? the switch 'activates' the solenoid every time without fail so would that not indicate that it's ok that end?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #9 on: December 19, 2018, 01:20:09 PM »
Carefull with the small wires as early bikes are different to later ones. If the starter button circuit has high resistance somewhere it may be dropping the voltage enough to not pull in the solenoid properly but still click, having said that from symptoms given i would suspect bat internal main contacts on the solenoid which is/was not common but these are all very old now so new and different faults are occuring.
« Reply #10 on: December 19, 2018, 01:22:41 PM »
Or it could be a cruddy start switch
Offline ka-ja
  • ken
  • yoshi 460
« Reply #11 on: December 19, 2018, 08:37:27 PM »
If the solenoid clicks, it is a good guess it is operating but there is no flow of power past the contacts, bad contacts often work intermittantly before failing altogether, time for another solenoid
« Last Edit: December 19, 2018, 08:42:41 PM by ka-ja »
nice bike,nothing in the bank
