Author Topic: CB500K1 stiff clutch lever  (Read 2021 times)
Offline AndyH
  • I'm privileged to be a
« on: December 20, 2018, 09:23:13 AM »
Contrary to some unsubstantiated rumours that I'd sold my 500K1, it's still with me!  8)
Something that's been annoying me for quite some time is the stiffness of the clutch lever.  Engagement of the clutch itself is fine, with no "grabbing" or suddenness (is that a word?) so I think I've got the adjustment fairly right.  I've removed the cable and checked that there's no problem there, but a few months back I replaced the various oil seals on the LHS.   Perhaps I didn't put enough grease in the clutch lifter and adjuster assembly when I put the cover back on.  The silly little grease nipple on the cover itself is NFG in my view.....I have a small nipple grease gun but I couldn't force any grease in.  >:(
All ideas/suggestions on how to make the lever smooooooth gratefully received!  ;D
Meanwhile,  a Very Merry Christmas and a Safe and Healthy 2019 to all and sundry from "Down Under, West of Everywhere"!!  :) :)
« Last Edit: December 20, 2018, 09:26:48 AM by AndyH »
Andy
1971 CB750K1
1972 CB500 Four K1 (SOLD)
1978 Suzuki GS750E
Previously....
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Re: 500K1 stiff clutch lever
« Reply #1 on: December 20, 2018, 09:25:21 AM »
Always worth trying a new GENUINE cable, you'd be amazed at the difference compared to old ones or pattern parts.
« Reply #2 on: December 20, 2018, 10:01:36 AM »
+1 And make sure cable is routed correctly.
Offline AndyH
Re: CB500K1 stiff clutch lever
« Reply #3 on: December 20, 2018, 10:15:58 AM »
Thanks guys, I think you're right.  I'll purchase a replacement cable.
Are "slinkyglide" worth a look or should I simply go OEM?
Andy
1971 CB750K1
1978 Suzuki GS750E
Previously....
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #4 on: December 20, 2018, 11:11:05 AM »
OEM will be the best available, tried many pattern makes over the years, but OEM always sorts it.
« Reply #5 on: December 20, 2018, 12:13:59 PM »
Here some details of a genuine cable. Compare that with imitation products... Never had one break. Replaced one after ca. 60.000 kms. The second one has done 75.000 kms now, but probably needs replacement soon.
« Reply #6 on: December 20, 2018, 01:52:20 PM »
Is pushrod in one piece?
Offline peterengland
« Reply #7 on: December 20, 2018, 04:58:45 PM »
KM's ? thought this was the UK   :)
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline flatfour
« Reply #8 on: December 20, 2018, 05:22:10 PM »
I change the clutch cable on my K1 every couple of years, as the 500 clutch is already heavier than the 750 and it does make a difference. I use DS cables, which seem to work well, however there often seems to be a shortage of supply so now, as with many other parts, I keep a spare on the shelf in the garage.
I am gradually building up a stock of spares for the old Honda's that I have and I even recently persuaded myself to buy a second sprocket carrier from CMS for the CB500 in case of future need.
Offline AndyH
« Reply #9 on: December 22, 2018, 08:15:14 AM »
It's in one piece Bryan.  :)
Andy
1971 CB750K1
1978 Suzuki GS750E
Previously....
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #10 on: December 22, 2018, 08:21:06 AM »
Check that the ball is in the lifter and it is nice and round, a slight flat spot can give problems  ;)
Offline AndyH
« Reply #11 on: December 22, 2018, 10:44:25 AM »
When I did the seals I checked the ball Trig.  All OK.
I'll replace the cable (trivial cost when all said n done) and report back.
Andy
1971 CB750K1
1978 Suzuki GS750E
Previously....
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1979 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline Tomb
« Reply #12 on: December 24, 2018, 11:12:45 AM »
What condition is the clutch actuating helix thread?
http://forums.sohc4.net/index.php?topic=89065.0
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #13 on: December 26, 2018, 08:32:08 AM »
If not already see if it’s routed above the left tank mounting lug.
When I altered mine to that route it seemed to help, and I think my old one was back in the 1970s.
Regards Jeremy
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #14 on: December 27, 2018, 09:33:18 PM »
Left? ???
