Author Topic: CB500K1 stiff clutch lever  (Read 2037 times)
Re: CB500K1 stiff clutch lever
« Reply #15 on: December 27, 2018, 09:33:18 PM »
Left? ???
« Reply #16 on: January 04, 2019, 07:13:15 PM »
If not already see if it’s routed above the left tank mounting lug.
When I altered mine to that route it seemed to help, and I think my old one was back in the 1970s.
Regards Jeremy
Jeremy, can you inform us exactly how the clutch cable is supposed to be routed?
« Reply #17 on: January 04, 2019, 10:18:19 PM »
Regards Jeremy
  I will check later,but I am sure it goes from the lever ,round the  headstock,under the RH tank mount,through the hole in the frame next to the coils ,down between the 2 LH carbs,rubber mounts and onto the final drive case,.
 try that ,keep the bends as wide open as possible ,the larger the diameter,the better
