Author Topic: loose needle and debris in sump  (Read 531 times)
Offline Windycorner
« on: December 20, 2018, 04:29:09 PM »
Did the first oil change I've done on this bike yesterday, and a loose needle came out of the sump drain hole, also what looks like sand came out of the oil filter housing, so I dropped the sump and its full of gritty sand and sludge, so I have no idea were the needles from and I am now thinking I will have do a full strip and check everything, and an other thing is the exhaust silencer was cut in half at the join with the collector box just the gasket was pushed in as a seal >:( and it was a new honda sankei silencer as well,
I've read Julies rebuild post a couple of times I am sure I can do it, just the gearbox layout frightens me and of course what other horrors I will find in there. I will try and attach some photos.
Neil
Neil
CB750FA
CB400F2
Re: loose needle and debris in sump
« Reply #1 on: December 20, 2018, 04:54:22 PM »
That all looks interesting Neil. The gritty sand and sludge would be more worring to me than the needle you found as all that debris and swarf has been going around the engine at some point. I really struggled with the gearbox layout and components as well and had to have it explained to me more than once. But, there are plenty on here who will help talk you through it if you get stuck but, I'm sure you will be fine.
« Last Edit: December 20, 2018, 04:56:29 PM by Nurse Julie »
« Reply #2 on: December 20, 2018, 09:41:31 PM »
That needle loks like a shaft bearing needle and the sludge looks like the cam chain has been rattling a lot. Strip it soner rather than later
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: December 21, 2018, 05:18:55 PM »
..maybe the sand stuff is because a Beach boy had it at one stage? 8)
« Last Edit: December 21, 2018, 05:23:20 PM by Athame57 »
1978 CB400F2 called Elen.
