Author Topic: Cb750k6 clutch disc query  (Read 2652 times)
Re: Cb750k6 clutch disc query
« Reply #30 on: January 12, 2019, 11:07:57 AM »
Here you go! A K6 clutch and i have put a picture of the different springs ( both OEM ) and a clutch plate that has gone hard and brittle.
Offline Paulreade
  • SOHC newcomer
  • Carpe diem
« Reply #31 on: January 12, 2019, 11:53:33 AM »
Thanks trigger, on the face of it looks very similar but will brave the cold in the garage and compare later.
On the springs I want to fit the shorter new springs - can you see advise if you for see a problem with that at all ( from memory they measured 32.7 mm as opposed to 35mm for the removed Spring)
Clutch plates ( new ck1145) have been in soak overnight ready for install.
Many thanks
Paul
Suzuki GSX 1250 FA
Triumph t100 bonneville
Honda cb750 k6
« Reply #32 on: January 12, 2019, 12:00:34 PM »
The longer spring with give a smoother operation and a better lever  ;)
