Author Topic: I've bought UK Pete's Ruby Red K1  (Read 1344 times)
Offline Andrew-S
Re: I've bought UK Pete's Ruby Red K1
« Reply #15 on: December 23, 2018, 02:07:21 PM »
Thanks for the heads-up, I'll look into that stuff.
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline Sgt.Pinback
« Reply #16 on: December 23, 2018, 07:07:34 PM »
Lovely patina.
cheers, Uli
Offline Andrew-S
« Reply #17 on: December 24, 2018, 04:48:26 PM »
Bit of progress on the K1 today, spent 4 hours cleaning up some of the sharp end - tried a new product (to me) for cleaning and protecting chrome and plastics; 'Quick-Glo', pretty happy with the result after the first effort:
1976 UK Z900 A4
2018 BMW R1200 GS
Offline UK Pete
« Reply #18 on: December 24, 2018, 05:10:56 PM »
Wow it works well
« Reply #19 on: December 24, 2018, 06:13:27 PM »
Andrew - I use Bilt-hammer Deox-C to derust my tank internals. You Do need to flush out any gunk/varnish residue first. I normally remove the stale fuel, then degrease / flush (if you’re careful you can use a pressure washer lance to clean out internally. Then make up a Deox-c solution with hot water and fill the tank with the solution warm.
Been using that stuff for many years as we have a 40 litre heated bath of it where I work BUT .. don't leave any chromed parts in it for an extended period as I left a CB250K front guard in it and it started to strip the chrome under where the original pitting was. Having said that a quickish immersion of a USA 500/4 rear guard worked wonders on the underside.
