Author Topic: Float heights  (Read 2588 times)
Offline Dave M
Float heights
« on: May 15, 2008, 08:22:00 AM »
Hi all.
My CB550F2 was registered in September 1978 and my Haynes manual goes up to 1977.
In said manual Mr Haynes says that the carb float height for the F model is 22mm.
I'm assuming that this will be for the the F1 model. Can anyone confirm that this is the right setting for my F2 carbs?
Dave
Melbourne.
Re: Float heights
« Reply #1 on: May 17, 2008, 11:19:10 AM »
Depends on the type of carbs mate, look on the top and see if the top cover is "coffin" shaped hald on with a screw at each side or "P" shaped held on with a screw at top and bottom.
It ought to be the former and have the same float setting as the 500.
Offline Dave M
Re: Float heights
« Reply #2 on: May 18, 2008, 06:50:30 PM »
They do have the coffin shaped tops so is Mr Haynes right at 22mm?
Dave
Melbourne.
Re: Float heights
« Reply #3 on: May 19, 2008, 03:56:40 AM »
Thats what it sez in my Genuine Honda book so for once Mr Hynes has copied it right
Offline Dave M
Re: Float heights
« Reply #4 on: May 19, 2008, 07:35:17 AM »
Thanks Bryan.
Dave
Melbourne.
