Author Topic: Cb750k1 ignition switch?  (Read 541 times)
Online Arch stanton
« on: January 02, 2019, 12:26:56 PM »
Hello.
Does anyone here know if the 750K1 switch differs from a
Cb175 switch?
Its just that I have a Nos 175 switch. That appears to match the 750 item. But I'm not sure if the contacts within the switch will make the correct connections.
Any help will be appreciated.
Sean.
Re: Cb750k1 ignition switch?
« Reply #1 on: January 02, 2019, 02:00:49 PM »
Check the part numbers at cmsnl
Online Arch stanton
« Reply #2 on: January 02, 2019, 05:33:31 PM »
Already done that. They are different.
The switches look the same & the plug /socket match.
But when I tried to fit the switch on my Xl250 motorsport
It made the wrong connections.
I would like to use up this switch if I can. Rather than buy another & still have this one stuck on the shelf.
« Reply #3 on: January 02, 2019, 10:49:01 PM »
Only real way is to plug it on and see and/check it out with a multimeter, dont think the xl had points so ignition wiring would differ
Online Arch stanton
« Reply #4 on: January 03, 2019, 09:47:56 AM »
The Xl Motorsport has points.
But the switching was different.
I've got my Brother coming round tonight to have a look at the electrics. He's a bit of a wiz with this sort of thing.
But most of all he's got patience. Something I don't have.
