Author Topic: Swapping oil tanks?  (Read 505 times)
Offline theshootist
Swapping oil tanks?
« on: January 16, 2019, 09:04:03 AM »
Hi,
Does anyone know whether the oil tank from the K series bikes can be fitted to the F1? I can see that the oil lines come out of the tank differently, but not sure if that procludes putting on the earlier tank.
Re: Swapping oil tanks?
« Reply #1 on: January 17, 2019, 03:44:38 PM »
I am sure that this question has been asked before by Phil ward and i put some pictures on the tread. The tank mounts and frame are different so, no. There are basically 4 tanks for the K and it is only the K0, K1 to K5 and the K6 have the same mounts  ;)
 Pictures in this thread >>> http://www.sohc.co.uk/index.php/topic,9048.msg62071.html#msg62071
« Last Edit: January 17, 2019, 03:47:46 PM by Trigger »
Offline theshootist
« Reply #2 on: January 18, 2019, 04:33:34 PM »
Thank you Trigger - I did spend some time searching but didn't find that thread.
Looks like I will keep tothe later style.
