Is there a specific resource which would show me specifically, on these carbs, what parts are what and where they go... the jets and float valve and such I know about, but what about the different passages? I'm looking to dismantle the carbs enough to replace the rubber bits and clean everything as best I can, but without separating them, which means carb cleaning spray and compressed air. And probably some degreaser for the exteriors...
I have both. Interesting that the Honda service manual doesn't mention the needle grooves...
Personally I would not remove the back plate and split the carbs if I didn't think there was a problem that needed attention. I would pay more attention to the bits I can get to and make sure they are as clean as possible and fit new O rings etc. If you do need to remove carbs from the back plate and spit them, it is easy enough but it doesn't sound like it's necessary in your case.
Quote from: mattsz on January 20, 2019, 02:57:10 AMI have both. Interesting that the Honda service manual doesn't mention the needle grooves...if you have the 'shop manual - honda cb350f-400f' (hwm002) by honda then its right at the back on page 95!
Someone gave me a carb jet cleaning tool. Bikemaster says it's a necessity. Is this useful, or should I avoid it like the plague?https://bikemaster.com/carburetor-jet-cleaning-tool.html
I have a set of those in Pink, purchased from Mr Silver many years ago. I use them on everything.....except carbs and never ever to clean out jets
