Author Topic: carb problem  (Read 865 times)
Offline RGP750
carb problem
« on: January 19, 2019, 05:27:37 PM »
Hi Guys
Not sure what is happening here??
Almost finished a CB175 for a mate in Wales and started today and when I CLOSE the choke the engine revs rise a great deal.
Can anyone tell me what is going on as I haven't a clue .
Cheers Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: carb problem
« Reply #1 on: January 19, 2019, 06:45:32 PM »
Just a bit of girlie logic.
Are they opening when you think they are closing and vice versa?
 ie, are you operating the lever in the correct direction.?
Offline RGP750
Re: carb problem
« Reply #2 on: January 19, 2019, 06:57:11 PM »
yes Julie same principal as the 750 Weird ????
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Re: carb problem
« Reply #3 on: January 19, 2019, 06:59:50 PM »
Weird indeed Richard.
Re: carb problem
« Reply #4 on: January 22, 2019, 08:31:26 PM »
When you lean off the mixture the revs rise.... as long as it starts ok with choke in the cold and then runs ok without choke when warmed up, without being too lean. Its ok.
It may be initially set up too rich so the choke is killing it and the rich condition means it run ok without choke when cold.... whats it like when its fully warmed up?
Offline RGP750
Re: carb problem
« Reply #5 on: January 23, 2019, 06:58:07 PM »
Hi Rob
I put another set of carbs on and all is fine .
I couldn't shut the choke without the revs rising to 8000 weird.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Re: carb problem
« Reply #6 on: January 24, 2019, 12:42:42 PM »
wow! that is weird... did you get chance to examine the carbs to see if you could spot the issue? would be interesting to know..
