Author Topic: Carb Balancing  (Read 2515 times)
Offline Dave M
Carb Balancing
« on: June 06, 2008, 07:53:02 AM »
I've now received my replacement vacuum adaptor so I'm finally going to balance the carbs after their stripdown.
What should I set the idle speed at to do it?
I'm sure I read somewhere that it should be a fast idle, around 1800rpm and not the standard 1200rpm.
Is this correct?
Dave
Melbourne.
Offline matthewmosse
Re: Carb Balancing
« Reply #1 on: June 06, 2008, 10:38:50 AM »
I'd set to 1200 if possible, very much faster and mine gets hot and bothered in traffic, giving rise to oil leaks from the top end once :-[ mind you I'm too wide to filter which ain't a problem for most bikes. The trade off from being able to terrify hichhikers ;D
Re: Carb Balancing
« Reply #2 on: June 06, 2008, 12:19:55 PM »
Set at a 1100 tickover and check at 2,000ish
Offline Dave M
Re: Carb Balancing
« Reply #3 on: June 06, 2008, 03:53:24 PM »
Thanks for the info.
Dave
Melbourne.
