Author Topic: Old wires !!!  (Read 1819 times)
Offline vraksianrebel
Re: Old wires !!!
« Reply #30 on: January 29, 2019, 06:43:19 PM »
I think I need to find a new plug to go into the ignition on mine. Is there a source I can use or is it just a case of trial and error with some generics?
Offline matthewmosse
Re: Old wires !!!
« Reply #31 on: January 29, 2019, 07:25:10 PM »
Vehicle wiring products do a fair range, but the plastic housings for the 6mm multi blade connectors are different, however the actual click in metal terminals are compatible so it's a case of re use the plastic but replace the metal, which does take some patience and a fine screwdriver and pliers to get the old metal contacts out.
