Author Topic: Is there an alternative swingarm  (Read 1223 times)
Offline paddyz1
« on: January 30, 2019, 06:01:43 PM »
Currently doing a cafe racer project and i want to change the swingarm if possible. Maybe a inch or two longer.
Are there any bolt-on's or can you reccomend someone who will build one?
Re: Is there an alternative swingarm
« Reply #1 on: January 30, 2019, 07:05:49 PM »
Dresda used to make them a long time ago, also the collar and bushes are the same as the 750 BUT i make nosugestion that it would fit!!
« Reply #2 on: January 30, 2019, 07:51:23 PM »
Here's a link to Desda Autos now based in Rusper, Sussex.
info@dresda.co.uk
DRESDA Autos
Howells, Friday Street
Horsham
West Sussex
RH12 4QA
Tel +44 1293 871-887
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline paddyz1
« Reply #3 on: January 31, 2019, 10:12:18 AM »
Nice one thanks
Offline Arch stanton
« Reply #4 on: January 31, 2019, 01:49:46 PM »
Im about to fit a Dresda arm to my 750k1.
So I thought I would get it powder coated.
I wanted to fit new shock bushes. The method I use to remove the old bushes is to burn them out with a blow torch.
Then cut the outer ring & push it out. Simple as that But...
I could not believe what Dresda had done. They had welded the outer shell of the bushes directly to the swing arm. No housing or anything! A bit cheap considering they were quite expensive in the 70's
So I'm going to have housings made & welded on to take the bushes. As Dresda should have done originally
Offline matthewmosse
« Reply #5 on: January 31, 2019, 02:25:49 PM »
Ah, this is interesting. I had a cb550 project with a box section swing arm, the rear shock mounts looked like an afterthought. I assumed it was just a bodge up by a previous owner. Could you tell me, did dresda use tapper roller bearings in their cb550 swing arm. If so, I have one in my shed. Needs new bush mountings on the swing arm....
« Reply #6 on: January 31, 2019, 04:55:08 PM »
I think it's safe to assume they did.
« Reply #7 on: February 07, 2019, 11:29:39 AM »
Early GSXR 750 (f/g/h) ones fit - but they are getting harder to find now.
Apparently the pivot width is exactly the same, although some modifications are needed as it's a monoshock one and a bit longer too, so will need shortening. There is a thread in the US site that has this bike in, but I can't locate it just now.
This one also uses early GSXR wheels. I'm not sure what the forks and brakes are though. They aren't Slabside GSXR and the blue fork tops/ adjusters make them look a lot newer.
Cracking bike - it looks great, and it's a proper race bike too so probably goes pretty well.
« Reply #8 on: February 07, 2019, 06:58:05 PM »
Dresda one in the US version of a well known auction site. Not cheap though at £425. Is that what they usually cost?
https://www.motorcyclepartsdailyf1986.info/rare/cb550-dresda.html
Offline paddyz1
« Reply #9 on: February 09, 2019, 12:20:36 PM »
Thanks for all the responses guys
