Author Topic: rocker cover swap 550  (Read 565 times)
Offline Philh550
« on: February 04, 2019, 11:42:01 AM »
Hi, is it ok to swap a later model rocker cover (4 shafts) to an earlier one (8 shafts) ?
If so how are the 8 shafts secured ?
Thanks in advance Phil
Re: rocker cover swap 550
« Reply #1 on: February 04, 2019, 11:54:43 AM »
Yes it fits and they are not secured which is the reason for the modification.
Offline Philh550
« Reply #2 on: February 04, 2019, 02:06:33 PM »
Thanks Bryanj
do i put a little thread lock or similar on the shaft ?
« Reply #3 on: February 04, 2019, 04:29:48 PM »
What you can do to try and stop them rotating, which wears the cover holes oval, is put an O ring in the shaft hole before fitting the polished end cap, the steel pin with sealing O rings traps the extra O ring between shaft and pin to make shaft tight.
This is an idea from the US site which i have never bothered to try but they seem to be paranoid about wear in the holes.
Offline Philh550
« Reply #4 on: February 04, 2019, 05:49:52 PM »
Thanks Bryanj will have a look at that when all my bits come back
Offline matthewmosse
« Reply #5 on: February 04, 2019, 06:44:14 PM »
I think my shed has about 10 rocker covers, most cooked journal bearings or other faults, but I have yet to have a set of oval rocker shaft holes.... or indeed loose ones, far more common is the outside perimeter bolts having been over tightened and split the outside of the bolt hole off.
