Author Topic: Advancer cam  (Read 471 times)
Offline ogri211
Advancer cam
« on: February 06, 2019, 07:52:29 AM »
I am going to fit Accent Electronic ignition to my 400 I have been running one on my Kettle for 3 years without a hiccup my question is when I contacted Uwe at Accent he asked if my advancer cam was 13mm or 15 mm, I know there were 2 different types used could some clarify where it is I measure I would assume it would be the bore of the actual cam from memory it is shaped like a top hat and can be removed by taking off the bolt and opening the weights on the springs. Thanks in advance.
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
