Author Topic: 1967 CB450K0 Black Bomber Rebuild - By Royhall  (Read 50902 times)
Re: 1967 CB450K0 Black Bomber Rebuild - By Royhall
« Reply #450 on: March 21, 2024, 09:23:06 AM »
Hi Mo .. great that the needles are OK.
Iam thinking along the lines that magnets in the rotor may be slightly weak so I would connect the yellow and white wires permanently. However, dig out one of those Kawasaki voltage regulators out and I will tell you how to connect it. This will mean that if you did generate excess charge then the regulator would 'current dump' it to ground and wouldn't overcharge your battery. How does it read if you have the dipped beam on too? Worth checking
Offline mo goldie
« Reply #451 on: March 21, 2024, 03:57:32 PM »
are Ok Ash
well I have found one up so have a look at the pictures and see what you think to wire that in to stop overcharging of the Battery....... as for the lights on have not done that yet so one more thing to look at.
anyway I gave the Regulator a clean up and put it on the meter if that means anything to you ( but Not me LOL )
so hope that will work, it has two wires coming out one Black and one yellow/white.
Mo
« Last Edit: March 21, 2024, 03:59:09 PM by mo goldie »
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
« Reply #452 on: March 21, 2024, 10:55:01 PM »
The Honda regulator is a 3-wire unit Mo. I will have to look up that one you have
Offline mo goldie
« Reply #453 on: March 21, 2024, 11:41:57 PM »
Are ok...... well I Think the other one when i find it has 4 wires ........
and is a lot bigger one........... so if I can use this one Ash would be good, so I asum it go`s somewhere between the rectifier and the Battery ?.
Currant BIKES:
« Reply #454 on: March 22, 2024, 08:04:14 AM »
Leave it with me to investigate Mo. You also need to check your charge current with the lights on dipped beam.
« Reply #455 on: March 22, 2024, 09:39:23 AM »
Bl**dy hell I am now genning up on Kwak KH400 electrics ! Forgive me as I have sinned  :)
Must admit the Shop Manual looks pretty good though.
https://kawatriple.net/wp-content/uploads/2021/04/Workshop-Manual-S-KH-Series-1.pdf
So here you go Mo. On Kwak voltage regulator ... Black wire to Ground and Yellow/Green wire to Yellow on your wiring.
Offline mo goldie
« Reply #456 on: March 22, 2024, 11:25:02 AM »
Hi Ash
Well thanks for that and the Manual I have got one but got a spare Now.... going over to Kawasaki LOL
so here is what I have done this morning with the bike lights on and off Not to sure now as with the lights on the voltage drop a lot but I will let you tell me what you think, it starts off with the lights off and rev at 2,000 rev`s about 13.40 to 13.45 then lights on and drop right away to about 12.7 then go`s down from there to about 12.46 all at 2,000 rev`s don`t know if that is good enough or Not.
Cheers Mo
« Last Edit: March 25, 2024, 06:49:27 PM by mo goldie »
Currant BIKES:
« Reply #457 on: March 22, 2024, 11:47:57 AM »
Hi Ash
so here is what I have done this morning with the bike lights on and off Not to sure now as with the lights on the voltage drop a lot but I will ley you tell me what you think, it starts off with the lights off and rev at 2,000 rev`s about 13.40 to 13.45 then lights on and drop right away to about 12.7 then go`s down from there to about 12.46 all at 2,000 rev`s don`t know if that is good enough or Not.
Cheers Mo
Doesn't sound too bad .. can you do the same tests with meter set to 10A and in series with battery (as you did previously) please Mo and give us some current readings.
Offline mo goldie
« Reply #458 on: March 22, 2024, 12:13:03 PM »
Well Ash
I hope this make some sense to you as don`t to me  ;D
Just connected up in line with the batt and this is what the meter say.
Currant BIKES:
« Reply #459 on: March 22, 2024, 01:11:49 PM »
Mo .. you should only have the black probe going to the battery  .. that red lead from the rectifier needs to connect to the other red leads
« Last Edit: March 22, 2024, 01:21:19 PM by AshimotoK0 »
Offline mo goldie
« Reply #460 on: March 22, 2024, 01:19:44 PM »
the red lead is the one from the rectifier to the battery which is being held on by the black probe, and the other black from the Rectifier is to the - side of the battery the starter wire as we said is Not connected as use kickstart only.....
i wish I Know more Ash about Electrics  ;D
oh don`t forget I have the wires from the stator going to the Rectifier so Not going thought the loom.. the black rectifier wire is the yellow from stator which is the white ( lights Extra ) ...and the brown/yellow is the yellow from the stator both connected to rectifier.........
Confusing .com I Know lol
« Last Edit: March 22, 2024, 01:28:06 PM by mo goldie »
Currant BIKES:
« Reply #461 on: March 22, 2024, 01:26:09 PM »
You definitely need to connect the red lead from the rectifier to the red probe from the meter and only have the black lead connected to the battery. Idea is to measure current in to or out of battery.
Offline mo goldie
« Reply #462 on: March 22, 2024, 01:29:27 PM »
are ok
I will go have a go at that then Ash Thanks.....will get back :)
Thanks for this  ;D
Currant BIKES:
Offline mo goldie
« Reply #463 on: March 22, 2024, 01:49:26 PM »
are there you go Ash
is That any better ....... that was lights on and 2,000 rev`s.
Oh that wire you pointed at I will go look see if I can find out where it go`s.
« Last Edit: March 22, 2024, 02:13:36 PM by mo goldie »
Currant BIKES:
Offline mo goldie
« Reply #464 on: March 22, 2024, 02:53:44 PM »
I have just done that search of the wire and its is just a loop which go`s from the battery the one you pointed at to that sort of red Felt pen colored wire coming out of that right side plug which must be the feed out from the rectifier to charge the battery into that.
oh thats my KH400 Ashley back in 2008 in Classic motorcycle Mag
« Last Edit: March 23, 2024, 12:01:44 AM by mo goldie »
Currant BIKES:
