Author Topic: Leaking Carbs (oh God a nighthawk question)  (Read 3411 times)
Offline JonnyB
    • BatchScan
« on: July 16, 2008, 06:16:57 PM »
Well not so much as leaking, more like P##sing out.
Finally got some spare time, so I thought I'd prep the wife's CB650 (yes it's the Nighthawk), ready for its MOT. It's been under cover in the shed since July last year, but what with rising fuel prices she's decided to get back into the saddle.
Anyway, no problem starting it up, even though I think the choke is stuck open, but it absolutely pisses fuel from number two carb, but only when the engine is running. Revs up fine too, and as soon as you switch the ignition off the leak stops ( I said go with it, it's still doing less to the gallon that the car - Kidding ).
Not had time to strip it yet, but as far as I can see the leak is not from the float overflows.
Has any one else experienced anything like this (Think of it as a fuel/carb/vacuum tank issue and not a Nighthawk problem)
Look forward to your advice, and any derisory comments about nighthawks. :D
John
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
Re: Leaking Carbs (oh God a nighthawk question)
« Reply #1 on: July 16, 2008, 10:18:54 PM »
OK. Assume this "Nighthawk" thingy has a vacuum fuel tap, so only leaks when the engine is running.
We need to know where it's leaking! If it's not the overflow then where?
2022 Tiger Sport 660
Offline JonnyB
    • BatchScan
« Reply #2 on: July 17, 2008, 01:04:12 PM »
I'll get the tank off tonight and see if I can locate it, but I've never seen a leak like this before. When you peer under the tank it's higher than the float bowls and seems to be coming from the top of the carb itself.
John
Offline matthewmosse
« Reply #3 on: July 17, 2008, 01:14:56 PM »
Split fuel line? blocked overflow an stuck float? My 500 developed a strange thirst that ended up being a split in the (new) fuel line ???
« Reply #4 on: July 17, 2008, 03:02:49 PM »
Perished/split diaphragms?
Offline JonnyB
    • BatchScan
« Reply #5 on: July 17, 2008, 07:14:54 PM »
Well, I'm stumped....
Just started it tonight after spending a hour clearing space in the shed to work on it and it's stopped leaking.  ???
John
« Reply #6 on: July 18, 2008, 04:40:03 PM »
If it dont leak it aint broke;
If it aint broke leave it alone!
Ta Ra problem fixed so ride it
Offline JonnyB
    • BatchScan
« Reply #7 on: July 21, 2008, 07:13:52 AM »
Waiting for a new choke cable, I'll let you all know if it leaks again.
John
