Author Topic: Head o ring replacement  (Read 450 times)
Offline paulbaker1954
« on: February 19, 2019, 08:16:31 AM »
I have a slight oil leak that i am sure emantes from the o ring between the head and jugs
Is there any easier merhod to replace this without taking the head fully off
I suspect not but thought id ask in case there is an easy way
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Head o ring replacement
« Reply #1 on: February 19, 2019, 10:14:54 AM »
Easy answer no BUT check the leak is not from an end cap area first
« Reply #2 on: February 19, 2019, 07:58:12 PM »
As Bryan said, impossible  ;D
Did you use a aftermarket head gasket and the o ring that came with it ? The Honda head gasket was 0.8mm thick and a lot of the aftermarket ones are 1mm. The problem with a lot of the aftermarket suppliers is they just used the data from Honda for the o rings and a lot are not thick enough to make a seal with a 1mm head gasket so, a upgrade is needed  ;)
« Reply #3 on: February 20, 2019, 04:34:59 PM »
Hi Trig
Thats exactly it i think
Can you recommend o rings that will be ok
