Author Topic: CB750 HT Leads  (Read 507 times)
Offline SteveCR7
CB750 HT Leads
« on: February 24, 2019, 11:58:24 AM »
Is there any way to replace the ht leads on Honda CB750 coils. I have a broken lead right as it comes out of the coil.
Thanks Steve
76 Rickman CR750 (resto in progress)
73 Kawasaki H1D (sunny day madness)
02 Triumph Sprint ST955 (commuter and long distance)
Re: CB750 HT Leads
« Reply #1 on: February 24, 2019, 12:08:17 PM »
Thanks Steve
Yes.search the forum for Ashs repair method.
It can be done
Offline SteveCR7
Re: CB750 HT Leads
« Reply #2 on: February 24, 2019, 12:43:02 PM »
Thanks John I will have a look
Offline H2Eric
Re: CB750 HT Leads
« Reply #3 on: February 24, 2019, 05:23:22 PM »
Easy to do. I followed Ash's instructions with just a slight variation.
I first filed a flat on the coil above the lead and then used a sharp chisel to gouge out the plastic above the lead. I kept digging until all the lead was exposed right back to the metal pillar to which the lead is attached. A Dremel with various burrs helps.  I removed the old lead completely. You should now have a trough into which the new lead will be inserted. I then drilled a 1.5mm hole in the pillar. I used new silicone leads into which I inserted a short length of 1.5mm copper wire into one end leaving about 15mm protruding from the end, this is then inserted into the pillar and soldered up with the lead fitting snugly in the trough. A bit of araldite to seal the join and leave to set. I left mine overnight. Then I used black Milliput to finally seal in the lead and once set filed to the original shape.
Eric
