Author Topic: Centre Stand cushion  (Read 863 times)
Offline Athame57
    • SeaWitch Artist
« on: February 28, 2019, 11:49:58 PM »
I noticed my centre stand when up is in contact with my exhaust and I'm not sure that should be the case as nowhere can I see a rubber cushion I'll swear exists to stop that ....?
1978 CB400F2 called Elen.
Re: Centre Stand cushion
« Reply #1 on: March 01, 2019, 08:23:04 AM »
There should be a rubber pad that fits into a hole in the silencer near the mounting plate.
They are available.
Offline Deano400
« Reply #2 on: March 01, 2019, 10:05:09 AM »
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: March 01, 2019, 06:16:39 PM »
Thanks for that!  ;D
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: March 05, 2019, 02:46:47 PM »
Cushion arrived in the post today and i went straight downstairs to fit it, alas no joy. I fitted the rubber T stud on the back of the cushion into the groove on the silencer that also holds the bolt that secures the silencer to a brace between it and the frame. As I really expected the stand simply kicked it straight off again. The grooves on the cushion face side on too, I doubt they are meant to do that, face on would be more like it. Is there supposed to be a seperate brack to carry this cushion that I'm missing?
« Reply #5 on: March 05, 2019, 03:00:51 PM »
Photos from underneath George.....including dirt (still  ::)
Offline Athame57
    • SeaWitch Artist
« Reply #6 on: March 05, 2019, 03:05:49 PM »
Thanks for the images Julie that explains it, my silencer does not have the same fittings. I'm going to have to invent something.
« Reply #7 on: March 05, 2019, 03:07:49 PM »
That would explain it George. This is a Brituro silencer, which have the same fittings as the OEM silencer.
Offline blackeagles
« Reply #8 on: March 06, 2019, 04:16:16 PM »
a rubber door stop maybe?
i have a motad silencer with a bracket from something else so the stand was hitting the bracket and i fitted a door stop.  it may not look great but it works!
« Last Edit: March 10, 2019, 09:57:28 AM by blackeagles »
