Author Topic: Wiring help please  (Read 1315 times)
Offline sye
Wiring help please
« on: March 02, 2019, 05:06:05 PM »
Hi, I had to buy a new loom for the K1 which seems to be missing a connector (or two). the bike has the additional 2-way lighting switch marked HL - OFF. There are two wires that come from this, one black (live) and the other brown with a blue stripe. My loom has no matching wires for the brown/blue wire and I can't find it on the wiring diagram. Has anyone come across this before and know the work-around.
This is the loom I bought: https://www.ebay.co.uk/itm/Main-Wiring-Harness-32100-323-040-Honda-CB500K-1972-1973-WH-323/232588249294?hash=item36275708ce:g:0BsAAOSwmwtaKAGZ:rk:1:pf:1&frcectupt=true
Thanks.
« Last Edit: March 02, 2019, 05:09:02 PM by sye »
Re: Wiring help please
« Reply #1 on: March 02, 2019, 05:32:29 PM »
Brown/Blue wire normally is reserved for the turn signal buzzer. If you don't have a turn signal buzzer, so much the better. The beeper irritates and almost all of us disconnect it. A CB500 like yours had no less than four different Wiring Diagrams in the Owner's Manual (US, UK, General, Germany, France, European Direct Sales). Differences often are about the lighting and the horn arrangements. First check in the parts list what model (area code!) you have by comparing your engine- and framenumber with those listed in the first few pages of every CB500 Parts List. You find the parts lists here: http://www.honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb500
« Last Edit: March 02, 2019, 05:51:01 PM by deltarider »
Offline sye
« Reply #2 on: March 02, 2019, 05:50:13 PM »
Thanks but it's deffo for the headlight switch. I fail to see why it's there really, it's just an onn/ff switch for the headlights but there is already an an off/low/park/main switch on the right, so it's duplicating that in some way.
Unless this has a US R/H switch gear? I have no idea of the previous history, so it may be?
« Reply #3 on: March 02, 2019, 05:59:56 PM »
According to a parts finder the harnass is for the CB500K1(A) and the CB500K2(A). https://www.hondaparts-direct.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE# Both US models.
Offline sye
« Reply #4 on: March 02, 2019, 06:00:58 PM »
I've answered my own question I think? It looks like a US R/H switch as DSS show the UK one as not available but there is a picture as below. I can find a UK spec one but for more than I would like to pay  :'(, so it looks like I will leave it in place but it won't do anything.
The UK spec one appears to have two brown wires, one with a white stripe and another with blue, so that's the answer, I think.  ::)
« Last Edit: March 02, 2019, 06:06:39 PM by sye »
« Reply #5 on: March 02, 2019, 06:03:25 PM »
It was fitted as an extra by a lot of owners as it is very easy to plung yourself into darkness by pushing the RH switch too far and to the best of my memory we used to wire it between any black(switched power) and the white (dip) but nor 100%sure. It was more found on the 750 so maybe look at that diagram, brown/blue was the power into the dip switch when it moved to the L/H side.
Offline Seabeowner
« Reply #6 on: March 02, 2019, 06:16:21 PM »
You have a mixture of switches fitted.
For the K1 the separate H/L on/off was added to European bikes as the US had a RHS switch marked off,L,H (with a sealed unit headlight  I think) and Europe RHS the switch was P,L,H as we had a pilot/parking bulb in the H/L. The correct switch for a K1 is the P ,L, H switch 35300-300-730 I think.
Your RHS switch is the rare type fitted to the few K0s the appeared in the UK. And has the P as Bryan pointed out precariously between the high and low beam settings and as you say also has a off position.
I don't have a diagram for the UK K1, but Trigger posted one a few months back.
« Last Edit: March 02, 2019, 06:22:55 PM by Seabeowner »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #7 on: March 02, 2019, 07:26:59 PM »
The left and right switches are both wrong for a UK K1, also the grips  :o ;D ;D
Offline sye
« Reply #8 on: March 02, 2019, 08:03:44 PM »
And the correct ones are? Bought both left switches from DSS as the correct ones. Barstewards  8)
Offline sye
« Reply #9 on: March 02, 2019, 08:10:47 PM »
And the grips too come to think of it  :'(
« Reply #10 on: March 02, 2019, 08:22:51 PM »
Everything looks K1 to me....but not 500K1, possibly CB750 K1  ???
« Reply #11 on: March 02, 2019, 09:27:13 PM »
No US switch had a P Position as they did not have sidelights, US RH switch was off/Low/ High but the "detent" to turn off was more positive than UK one. My UK one in the 70's had the P position inbetween L and H with off at LH end with a poor "detent" and i got fed up of going dark on the country lanes covered in cowshite round Gloucestershire!
« Reply #12 on: March 02, 2019, 09:53:00 PM »
NOS UK CB500/4 K1 switch gear and grip [ Guests cannot view attachments ] [ Guests cannot view attachments ]
« Reply #13 on: March 02, 2019, 10:09:41 PM »
With P in the middle is 400, late 550 and late 750 as, the hi/low switch was on the left  ;)
but it was a different switch to what Sye has  ???
You also seem to have the D washers missing from the top yoke  ;)
« Last Edit: March 02, 2019, 10:13:01 PM by Trigger »
Offline sye
« Reply #14 on: March 02, 2019, 10:44:46 PM »
Nope, D washers both in place, in fact I have two spares I think. The handlebars are not original but they are drilled. From a 550 I think, so unless I re-drill them, the separate switch has to go on the right. The switches are a bloody nightmare TBH, there are so many options for different models and different countries. It also doesn't help that they are discontinued and when they do come up, someone wants the cost of a cottage in Wales for it.
Will stick with what I have until something comes up.  8)
