Author Topic: Throttle cable routing  (Read 559 times)
Offline sye
« on: March 09, 2019, 05:17:13 PM »
Looking at all of the available information the throttle cables run over the top of the R/H headlight ear, down the left side and through the coil hole. My question is, do they go between the wiring cluster and the headstock or between the wiring and the headlight shell? Seems a bit long next to the headstock and may pinch the wiring if they are in front.
Thanks.  ;D
Davelu88
Re: Throttle cable routing
« Reply #1 on: March 09, 2019, 05:30:22 PM »
Does this help
« Last Edit: March 09, 2019, 05:32:44 PM by Davelu88 »
Offline sye
« Reply #2 on: March 09, 2019, 05:32:54 PM »
It does, I haven't run them through the gap in the clock bracket, hmmm...
Offline Seabeowner
« Reply #3 on: March 09, 2019, 09:38:39 PM »
My K0 is similar to Dave's, but I think that mine go above the tank mounting bung. But the tank is on so can't check. I do know that on right lock they are pretty stretched and there is damage to the outer of one under the tank area after just a few thousand miles.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #4 on: March 09, 2019, 10:41:14 PM »
On a UK unit, over the ear, down the left and through the frame hole. Through the clock bracket is USA.
Offline Seabeowner
« Reply #5 on: March 10, 2019, 06:25:26 AM »
Good, that's the way I wired my UK K1. As above on the US model the cables are at a stretch on full right lock and have taken the paint off the top yoke.
Offline sye
« Reply #6 on: March 10, 2019, 09:08:51 PM »
Thanks all, looks as if I have it right as per Graham's post.
