Author Topic: Did the machine shop wreck my hub? (now with working pics, hopefully)  (Read 1459 times)
Offline matthewmosse
Re: Did the machine shop wreck my hub? (now with working pics, hopefully)
« Reply #15 on: March 27, 2019, 06:50:14 PM »
Very odd way to resort to doing it like that...... not how I would have tried to do it. Sure I have removed a fair few over the years and never had to resort to that.
Offline mattsz
« Reply #16 on: March 27, 2019, 07:06:50 PM »
The soggy paper towel method is very effective on blind bearing /bush removal. I was shown this method over 40 years ago and have used it many many times. It even works on broken seloc/roll/spring pins.
https://www.youtube.com/watch?v=ggsEewAg2YM
Now this I gotta see!  To the internets, Robin!
« Reply #17 on: March 27, 2019, 08:46:47 PM »
Adding that to the tips list next time I have some blind bearings to remove, in fact I think I have a rotating centre bearing to renew its bearings on. With respect to the machine shop who did the hub job this thread started with, I dabble in machineing jobs as time permits - on they might argue time vs cost constraints to why they did the job like that but frankly when a job like that crops up, a few minutes googling non destructive solutions is something well worth doing, every days a school day and I don't charge my customers for doing a bit of research before wasting time and materials with a bodge rather than doing it properly, bottom line is I'm teaching myself another skill and thsts handy. When I worked for an engineering firm, likewise I didn't put the time figuring out things like that on the job sheet but I did try a bit harder to avoid butchering the object
I was meant to be salvaging. I've removed lots of those type of bushings from motorbike wheels over the years and never had to drill the hub to do it, from memory I think a rawl bolt / expanding concrete fixing has served the perpouse a few times as has drilling through the bushing rubber portion and collapsing in the remains a bit with a chisel. Just seems a very odd way to resolve the issue.
Offline Winterfield
« Reply #18 on: March 27, 2019, 09:21:12 PM »
F me did they try selling you a pound of sausages as well. There are loads of methods to try before resorting to that. No doubt time and cost became a factor. The soggy paper towel method is very effective on blind bearing /bush removal. I was shown this method over 40 years ago and have used it many many times. It even works on broken seloc/roll/spring pins.
Time and cost did become a factor, as he charged me more because he said they were a pain to get out. Next time I'm going to save my money and give it a go myself.
Thanks for that link, something to try for next time.
Offline Winterfield
« Reply #19 on: March 27, 2019, 09:23:46 PM »
No pics for me to see either but now I’m replying, the pics show up in the lower previous posts - weird!  Anyhoo, at least they have left the strengthening webs in place - if they had been cut through I would have said it was scrap.  If you intend using it I would remove any burrs from Roger the bodger’s holes inside and out and leave a little radius on the edges to prevent ‘stress raisers’ where cracks can start.  If, however you decide not to use it, I might have a spare but not able to check for a week or so on my return.  Unfortunately it too will still have the metalastik bushes in.
Ian
I think for now I'll press on with it (perhaps try to have it repaired somewhere else), at least to make some progress. I would be very happy to take you up on that spare hub when you have a chance to check, thank you.
