Author Topic: Fuel tank  (Read 537 times)
Offline davefirestorm
Fuel tank
« on: March 31, 2019, 01:17:18 PM »
I intend replacing the the fuel tank on my 1975 750 F as the one on it has been welded and looks sh**e,one I intend using has a 16x1.5 mm male thread on as per photo,is this correct? I will stick a new tap on but Silvers want £65 for an F model tap,one off a Superdream will fit at £9.95.Whats special apart from the big price difference?
Honda CB650Z
Honda F6C Valkyrie
Re: Fuel tank
« Reply #1 on: March 31, 2019, 03:48:20 PM »
No idea but Honda used different sizes on different bikes and years.
Re: Fuel tank
« Reply #2 on: March 31, 2019, 04:58:01 PM »
I seem to recall the F1 is 20mm, and is larger than most other Honda's. Even the F2 is smaller. The 750 K5/6 and F1 use the same tap, but they are hard to find at a decent price, and second hand ones usually need the filter and sealing washer renewing, only available as a kit with no change from £20 for the genuine kit. Get an accurate measure across the outlet of your tank, just in case it's been changed for an F2 at some point in it's life.
Re: Fuel tank
« Reply #3 on: March 31, 2019, 07:28:59 PM »
It is 16x1.5 mm thread and a Superdream tap screws on ( just happen to have one in garage )
Honda CB650Z
Honda F6C Valkyrie
