Author Topic: My first post! Question regarding CB550 main jets.  (Read 509 times)
Offline Brian.
« on: April 19, 2019, 05:26:47 PM »
Good afternoon all!  I hope you are all enjoying the sunshine today.
I have a question regarding 1974 CB550 K1 main jets, to which I cannot find the answer anywhere:-
The main jets have the jet size (38) stamped on the flat face of the jet.  When they are fitted to the carb, should that face of the jet be visible?  Or does it go in the other way please, ie stamped face butting up to the bottom of the needle jet?
Thank you very much.
Brian.
Re: My first post! Question regarding CB550 main jets.
« Reply #1 on: April 19, 2019, 06:55:28 PM »
Your main jet should be stamped 100 and your slow running jet 38. The 38 screws in and the 100 pushes in at the o ring end and then the black spring clip  ;)
Offline Brian.
« Reply #2 on: April 19, 2019, 08:01:27 PM »
Thank you Trigger; yup you are right, I was mixing the sizes of the two up, I meant 100 for the main jet.  I shall try to keep up  ;D
So can I ask, when the main jets are fitted in place correctly, should the end of the jet marked "100" be visible, or should that end be the one that's pushed into the carb body and the unmarked end be visible please?
As I see it, it is possible to fit them either way because there are two grooves; one for the O-ring and one for the spring clip.
There is a reason why I'm asking!
Thank you again.
Brian.
« Reply #3 on: April 19, 2019, 08:18:46 PM »
Larger hole face the float bowl
First pic right, second wrong
Offline Brian.
« Reply #4 on: April 19, 2019, 08:47:20 PM »
Thank you for that Trigger.  I'm almost certain that mine are in the correct way round then.
I can only positively remember that mine have the numbers not showing when fitted but I do think coincidentally they are correct as per your first picture.  Thank you.
It's a longish boring story about my bike but essentially I removed the jets, cleaned them and refitted them as they were but I am beginning to realise that just about everything has been messed about with in an effort to get it to run properly so they could have been wrong when I removed them.
It just seemed odd to me that the jet size is invisible unless you actually remove the jet.
Hey ho.  There will no doubt be another carburettor question coming from me in due course then!
Thank you for your prompt responses, I do appreciate it.
Brian.
« Reply #5 on: April 19, 2019, 09:11:05 PM »
You can't go on where the number is stamped as, some manufactures have the numbers on the end  ;)
« Last Edit: April 19, 2019, 09:18:20 PM by Trigger »
Offline Brian.
« Reply #6 on: April 20, 2019, 08:32:06 AM »
Now I certainly hadn't thought of that.
I know that mine are all the same way round, I think I'll take one float bowl off just to check to eliminate that.
Thank you again Trigger.
Brian.
