Author Topic: Feels a bit wobbly  (Read 1223 times)
Davelu88
Re: Feels a bit wobbly
« Reply #15 on: April 22, 2019, 07:45:10 AM »
Thanks for that Erny , tyres first then see how it is before I tackle the forks  ;D
Offline Erny
  • CB750K7 CB550K1
« Reply #16 on: April 23, 2019, 06:30:26 AM »
I would start with bearing replacement by tapered one, I bet it cannot be good! And of course new tires.
Forks after.
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline florence
« Reply #17 on: April 25, 2019, 10:57:11 AM »
Agreed, everything all have said already but having said that, mine has always been slightly wobbly at low speeds and despite trying different tyres and head bearing etc it is now something I just put up with.  It only seems to be at a particular speed.  I don't think you will ever get it perfectly right.
« Reply #18 on: April 25, 2019, 03:40:47 PM »
Also check your wheel alignment - a straight edge, or tight string touching front and back edges of the rear tyre should be passing by the smaller front tyre by an equal amount. There are alignment marks on the swinging arm, but this method is more accurate.
Davelu88
« Reply #19 on: April 25, 2019, 04:02:35 PM »
Today i have checked the fork springs & they are right length at 460mm i have also replaced the oil with 15W  i previously had 10W in it & i could only take for a Short ride as its raining but it did seem a bit more planted and a bit less bouncy , am i right that the tight coils in the fork springs go down first .
« Reply #20 on: April 25, 2019, 09:19:47 PM »
If it is bouncy, check that the spokes are true  ;) ;)
Offline Green1
« Reply #21 on: April 29, 2019, 12:31:39 AM »
I don't think it actully makes a difference what way up the springs go.
The larger coils will always compress first
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
