Author Topic: Clunking noise from front sprocket area.  (Read 1769 times)
Offline Bradders
« on: April 21, 2019, 11:21:25 PM »
Evening all. Have just pushed my bike into the garage after riding home from work and have noticed a clunking noise that appears to come from the front sprocket area. When I push it backwards it doesn’t make the noise at all.  Any ideas what it might be? ( hope it’s not bad news🙁)
Offline Clem2112
  • Midlife
Re: Clunking noise from front sprocket area.
« Reply #1 on: April 21, 2019, 11:25:18 PM »
Chain hitting the swingarm at the front?
Check the free play in the lower run.
Offline Bradders
« Reply #2 on: April 21, 2019, 11:59:41 PM »
Have checked the free play Clem2112 and seems about right at 20 mm at the tightest point.
« Reply #3 on: April 22, 2019, 12:40:12 AM »
Check the front sprocket plate and bolts. The bolts may be loose. 😯
Offline Clem2112
  • Midlife
« Reply #4 on: April 22, 2019, 06:59:20 AM »
Rear sprocket also floats slightly on the rubber dampers, is there excessive play here?
Also look at the front/rear alignment of the sprockets.
Were all three items renewed as a set, a worn sprocket might make more noise on a new chain.
« Reply #5 on: April 22, 2019, 07:27:52 AM »
Check everything out as above, but it may just be a normal sound of the chain on the sprocket, some bikes do.... maybe a bit of chain lube will help
Offline Bradders
« Reply #6 on: April 22, 2019, 09:31:10 AM »
Thanks for your replies guys. Is the front sprocket easy to access so I can check?  I’m not much of a mechanic!
« Reply #7 on: April 22, 2019, 10:14:39 AM »
Remove the gear change linkage (10mm spanner), Remove 4 x screws,  pull off cover et voila, there's the sprocket.   Check it's not worn.
Offline Bradders
« Reply #8 on: April 22, 2019, 10:23:02 AM »
Thanks very much. Shall have a look when I get home from work tonight.
« Reply #9 on: April 22, 2019, 10:51:55 AM »
Also check the entire chain length for a stiff or seized link, it makes an awful sound if you have one. I had an "O" ring chain seize a link on my 750F1 many years ago, took ages to finally find what the problem was. Have never used an "O" ring chain since!
Offline Bradders
« Reply #10 on: April 22, 2019, 11:40:08 AM »
Have just oiled the chain and seems quite a bit better but will check the sprocket tonight. Thanks for your advice.
« Reply #11 on: April 22, 2019, 12:39:13 PM »
Sounds like typical seized/ dry links, check the whole chain to make sure all links are free and use plenty if good quality chain lube. It may even be a bit of grit or gravel causing it to not bend properly around the sprocket.
Offline billywingnut
« Reply #12 on: April 22, 2019, 07:42:47 PM »
Is your chain catching the chainguard?
Offline Bradders
« Reply #13 on: April 24, 2019, 09:09:00 PM »
Evening. Checked the front and rear sprockets and all seemed fine ( to my untrained eye). Also gave the chain a good oil. Seems quite a bit better, maybe will completely stop the noise when the oil works it’s way in more. Anyway thanks for all your advice.
« Reply #14 on: April 24, 2019, 10:04:34 PM »
Check that the sprocket bolts are not too long and that it is not a o ring or x ring chain  ;)
