Author Topic: Recommended Source for Condensers  (Read 1521 times)
« on: April 22, 2019, 10:20:16 PM »
Out for a ride today on the standard K2 and it started irratically mis-firing and surging/slowing. Managed to make it home and checked the usual  things - cleaned plugs, checked petrol tap filter, points and timing. Noticed lots of arcing on 2-3 points and guessed it was the condenser - changed for a spare and cured the mis-firing. The original condenser (and replacement) are after market and so in line with the advice I've read on the forum, have been trying to source some genuine condensers for piece of mind but the price at DS is about £30 each!
Can anyone recommend a proven alternative? - as at that price, I'll just buy an electronic ignition (have one on my CR750)
Offline adespin
Re: Recommended Source for Condensers
« Reply #1 on: April 23, 2019, 12:42:34 AM »
I fitted after market condensers from DS in Febuary and they are working fine, £19 inc' postage and VAT for the pair.
1971 cb750 K1
« Reply #2 on: April 23, 2019, 08:34:03 AM »
That's what I have in - just worried that they have only lasted 1500 miles and might let me down again (can't remember ever changing condensers in 40000 miles I did on my 500Four back in the 70's) - might just be bad luck
Sent from my Moto G (5) using Tapatalk
Offline Moorey
« Reply #3 on: April 23, 2019, 09:29:57 AM »
Or maybe good luck in the 70s doing 40000 on the same condensers.
Offline adespin
« Reply #4 on: July 14, 2020, 05:08:37 PM »
As a follow up to this post and my reply to it, the after market condensers from DS failed after 200 miles, bought another set from ebay at £16 delivered, one of these is now giving trouble, miss firing, back firing, so the last one is now fitted and cured the problem for now, but for how long, i'm fearfull about going any distance from home as the first time it happened i had to ride home ten miles on two cylinders. They do say buy cheap buy twice, but Silvers genuine Honda condensers are now £72 delivered, and their pictures look the same as the after market ones. Anyone else having this problem ?
« Last Edit: July 15, 2020, 12:02:09 AM by adespin »
1971 cb750 K1
« Reply #5 on: July 14, 2020, 05:50:52 PM »
I am going to fit a pair of range rover condensers by the coils, i had to get 10 so you can have 2 for a fiver plus postage
Offline adespin
« Reply #6 on: July 14, 2020, 08:00:08 PM »
Great, thanks but how do they fit, is it a straight swop ?
1971 cb750 K1
« Reply #7 on: July 14, 2020, 08:39:54 PM »
You just bolt the condensers to the coil mounr and connect the leads into the leads to points
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #8 on: July 15, 2020, 07:18:30 PM »
There are other threads on failed condensers. Could there be a basic problem such as a faulty generator, rectifier or coil causing it. Or even a bad plug cap or poor plug cap connection cause some sort of back surge.  A basic way of testing each might be useful.
« Last Edit: July 15, 2020, 07:40:08 PM by jeremypeachey »
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #9 on: July 15, 2020, 08:09:57 PM »
As I understand it,  increase of resistance in HT circuit along with minimal specification plug gaps will give the triggering/ switching components an easier time. That's for both points and condenser or electronic.
« Reply #10 on: July 16, 2020, 11:28:22 AM »
Very interesting overview to consider
http://nonlintec.com/sprite/cap_failure/
It's not unusual it appears that condenser quality is an issue for others too.
Interesting that the physical construction in his view is not particularly tolerant to vibrations,  and possibly the differential between originally supplied Honda components.
It looks like much of currently available components are just not matching OE fit regardless of how much they cost.
« Reply #11 on: July 16, 2020, 12:19:26 PM »
Would anyone care to dissect one of Bryan’s Range Rover caps?
Thanks for posting that Nigel, it’s the sort of non-emotional investigation we need.
2022 Tiger Sport 660
Offline adespin
« Reply #12 on: July 16, 2020, 12:45:38 PM »
  That is a very interesting article, i now know what is going on inside a condenser and why they fail. We are at the mercy of cheap shoddy goods, probably made in China regardless of what it says on the box.
1971 cb750 K1
« Reply #13 on: July 16, 2020, 12:51:57 PM »
I used to use Lucas car condensers, as fitted to Morris Minors or Landrover petrol engines. Used to cost around £1 each at the time, and genuine Honda ones were around a tenner each at that time. Like Bryan I fitted them beside the coils, and they never failed there. I think the heat and vibration of the original location was often the reason for failing.
« Reply #14 on: July 16, 2020, 01:33:01 PM »
I'm wondering if Hondamans system protects the condensers better due to the reduction in voltage etc.
I've asked him as I haven't heard from him for a while about the systems I wanted to order.
Yes,  it (as far as I can determine) takes the condenser completely out of use while it's in operation.  The points opening is just used as a signal of timing to his electronics, so switching virtually no load at all (the reason a condenser is needed) just being used to provide a pulse on time to trigger the additional system which are doing all the donkey work in switching the coils.
His system replicates points open time, dwell etc electronically if I understand the details correctly.
