Author Topic: Front forks /wobbly steering  (Read 1544 times)
Offline ricardo
Re: Front forks /wobbly steering
« Reply #15 on: May 07, 2019, 03:18:49 PM »
Bikers thanks.
No the steering doesn't vibrate or shudder. It feels as if the steering is imprecise. I seem to have to always be turning the bars  to keep the bike on a straight line. Probably more noticeable while on a bend
On another bike I once had with excellent steering it behaved like this  when my front tyre was below pressure
Does that mean anything different.?
Ricardo.
« Reply #16 on: May 07, 2019, 03:45:43 PM »
How old and what type is the tyre? Has this happened suddenly or always been there? Have you altered or adjusted anything recently?
Offline ricardo
« Reply #17 on: May 21, 2019, 07:32:30 PM »
hi. thanks for reply. Apologies for late response.
It was there when I drove the bike away. I thought tyre might have been a bit flat. it was a little. Toppoed air up and it helped somewhat. I have been doing other stuff since but all suggested investigations have not resulted in a solution. Tyre and wheel off so I;ll look at tyre and let you know.
Ricardo
Offline ricardo
« Reply #18 on: May 21, 2019, 07:43:09 PM »
tyre is 'hent (or Heng) sinh
Lettering a bit weird.
Tyre in good condition but the 2 parallel lines near the edge of the tyre seems a bit off centre. A clear gap between the inner one and the rim but not visible gap on the opposite side of the tyre.
Ive made no adjustments
Ricardo
« Reply #19 on: May 21, 2019, 08:27:03 PM »
Well you may have found your problem, the tyre is not mounted correctly! Deflate the tyre completely, and push the beading in the rim a bit. Smear tyre soap or similar around the inside of the rim walls/along the tyre bead, and re inflate until the tyre bead sits evenly around the rim, then adjust to the correct pressure and go for a test ride. If no improvement,get the tyre changed, it's probably knackered.
« Reply #20 on: May 21, 2019, 10:36:50 PM »
Also very cheap tyre. Did not have a good rep
« Reply #21 on: May 21, 2019, 10:45:15 PM »
Nowt wrong with cheng shins, I have one fitted to the front of my CB400/4 , best tyre i have ever had for stickability to the road. I have a Mitas or however you spell it on the back, and once again, absolutely fantastic. The only problem now is that my 400/4 handles so well with this combination, it makes me want to ride fast all the time 😁😁😁😁
« Last Edit: May 21, 2019, 10:48:16 PM by Nurse Julie »
« Reply #22 on: May 22, 2019, 03:04:58 AM »
Must have changed Julie, when i was fitting them, admittedly many eons ago, they were marginaly worse than the original Japanese rubber!!
Offline ricardo
« Reply #23 on: May 22, 2019, 08:53:41 AM »
Thanks to both of you. I have a spare used tyre which came with bike. Seems to have very little wear on it. As I'd be taking tyre off anyway should I replace it with this one?
Ricardo
« Reply #24 on: May 22, 2019, 09:46:26 AM »
If you have another tyre, then yes, change it. While it's off check the inner edge of the rim for rust or the likes. If there is any, clean it off, as it needs to be a smooth surface for the tyre to seat itself properly.
Offline Moorey
« Reply #25 on: May 22, 2019, 10:45:18 AM »
Well Julie I have been away in Devon and Cornwall for the last 5 weeks and have had the 400 superfour with us and done quite a few miles on it. On Monday I went out on the 350 and couldn't believe how bad it feels. I have been kidding myself about the Cheng Shings. Now awaiting new tyres been delivered.  4.00x18 and 3.50x18 if you have use for them you are more than welcome to them, seems such a shame to scrap new tyres. T don't blame the fact they are Cheng Shings I am just going to put the correct size tyres on the bike. :D
« Reply #26 on: May 22, 2019, 10:52:18 AM »
Yep, agree totally. The correct size tyres always help 😀😀😁
Offline ricardo
« Reply #27 on: May 22, 2019, 07:06:53 PM »
Thanks Julie.
Ill check in the manual and be sure that the right tyre is going on
Any views on using paint stripers to remove the black paint sprayed in the hub and rim. It seems the cheapest option?!
Offline ricardo
« Reply #28 on: May 22, 2019, 07:27:34 PM »
Now I'm confused. As usual.
Tyre spec according to Haynes is  front 3.00 S18 (4PR).
The spare tyre is 90/90-18 M/C 57P
I suppose the M/C is motor cycle but the rest is Chinese to me.
The existing Feng shui tyre is 3.00 -18. 47p
Advice please or I will have to walk everywhere
Ricardo
Offline ricardo
« Reply #29 on: May 23, 2019, 09:03:05 AM »
Many thanks for all the advice. I now have a plan
Ricardo
