Author Topic: Fuel level in bowls  (Read 456 times)
watty51
Fuel level in bowls
« on: May 05, 2019, 03:24:36 PM »
Just set the floats to 21mm as per cylmer manual (Cb350f). Checked level in each bowl, all exactly the same height (see photo) ....Still seems  a bit low,
each level is about 10mm from the top of the bowl. Would that be about the right fuel level
Offline sye
Re: Fuel level in bowls
« Reply #1 on: May 05, 2019, 04:04:47 PM »
When the floats are in the bowl the level will rise, so all is good.
watty51
« Reply #2 on: May 05, 2019, 04:08:19 PM »
Never thought of that. Many thanks for the quick reply
