Author Topic: Fuel flow from petrol tank  (Read 501 times)
watty51
« on: May 07, 2019, 08:31:26 PM »
Is there a specified flow rate for fuel leaving the fuel tank.
Basically I have held a old float bowl under a fuel hose coming from the petrol tank petcock and it took over 2 minutes to fill to the correct level.
More of a dribble on both the on position and reserve, and with the cap open and shut, makes no difference
Seems a bit slow to me but as I have no reference to go by I was hoping someone could help.
Many thanks the bike is a Cb350f
Offline Orcade-Ian
    • Older Vehicle Web
Re: Fuel flow from petrol tank
« Reply #1 on: May 07, 2019, 08:41:22 PM »
Sounds much too slow, I don’t have an exact figure. There is a circular brass filter screen inside the tap, sounds like that might need a good clean.  You need to undo the bottom bowl of the tap to remove it.  Easier with the tank off the bike and on its side on a cushion. There is an o ring above the bowl.  Might be worth removing and cleaning the tap.  It’s held on with two screws one outside and t’other one above the screen.  Another shaped o ring between tap and tank.
Ian
« Reply #2 on: May 07, 2019, 08:54:37 PM »
Recheck the flow with the filler cap open to eliminate a blockage in the fillercapvent.  It's most likely to be the fuel filter, blocked up with rust.
« Reply #3 on: May 07, 2019, 09:00:50 PM »
As above. The screens can get totally smothered with crap from the tank. Having drained my CB400/4 tank in the past via the petcock I  would say a float bowl should fill within about 2-3 seconds.
watty51
« Reply #4 on: May 07, 2019, 09:24:18 PM »
Blimey 2 to 3 seconds I’ll def give the whole petcock a good clean out.
I’ve tried checking with the fuel tank cap open and closed, made no difference at all to the flow rate.
Is there a quick way of getting the fuel out of the tank rather than using the petcock. At the rate it’s flowing I’ll be waiting a week
« Reply #5 on: May 07, 2019, 09:37:55 PM »
If you have a container with a really big opening, like a bucket, you can pour it out of the filler cap. Definitely sounds like a good clean / overhaul of the petcock will work wonders.
