Author Topic: Copper Washers on Cylinder head cover and side covers  (Read 821 times)
Offline paulbaker1954
« on: May 21, 2019, 11:37:30 AM »
Can anyone tell me what purpose these actually serve?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Copper Washers on Cylinder head cover and side covers
« Reply #1 on: May 21, 2019, 05:02:33 PM »
What copper washers where? Shouldnt be any on a 500/550
« Reply #2 on: May 21, 2019, 08:57:43 PM »
There are 8 of them Bryan, they sit under some of the camcover bolts and there are 2 fitted to the end cap bolts along with the alloy washer which sits at the bottom of the bolt. They are simply crush washers to stop oil weeping up the bolt and leaking over the camcover Paul.
Thanks Ken
« Reply #3 on: May 21, 2019, 09:00:57 PM »
They are a wafer thin that have been zink plated so, don't look copper. The later 550's had flange bolts  ;)
« Reply #4 on: May 21, 2019, 10:33:12 PM »
Never noticed copper colouring on any of those, perhaps the zinc plating had not worn off as most of the ones i did were 1st time strip.
Offline Erny
  • CB750K7 CB550K1
« Reply #5 on: March 02, 2021, 10:50:31 AM »
Reopening this topic - are mentioned washers fine to be reused (after check and eventual flattening /grinding) or needs to be replaced by new ones? HSM does not specify this.
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline Tomb
« Reply #6 on: March 02, 2021, 12:00:14 PM »
Any copper washers can be re-used if not damaged, copper work hardens so will need heating to cherry red colour and leaving to cool to anneal, they are then soft and should not need flattening/filing as they will do that when tightened down against. Of course this may remove the plating.
I make copper head gasket for my 4 cylinder bikes which I re-use in the same way.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
« Reply #7 on: March 02, 2021, 01:46:19 PM »
Back inthe day they were rarely replaced unless leaking
Offline Erny
  • CB750K7 CB550K1
« Reply #8 on: March 02, 2021, 02:07:25 PM »
Great, thanks
