Author Topic: Boyer micro coil connectors - source for replacements  (Read 824 times)
Offline paulbaker1954
« on: May 27, 2019, 08:38:36 AM »
I need to replace a couple of the ignition cables on my bike which has a full Boyer kit with micro coils
Trouble is I can’t easily find where to source replacement brass connectors that push on the coil terminals
Can anyone advise where I can get them ideally on fleabay
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline jon stead
Re: Boyer micro coil connectors - source for replacements
« Reply #3 on: May 27, 2019, 10:52:26 PM »
« Reply #4 on: May 28, 2019, 08:15:00 AM »
I saw these on eBay, might do the job
https://www.ebay.co.uk/i/322961908918?chn=ps&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=322961908918&targetid=522577457663&device=t&adtype=pla&googleloc=9046771&poi=&campaignid=1782815754&adgroupid=70885937722&rlsatarget=aud-629407026665:pla-522577457663&abcId=1139356&merchantid=7444344&gclid=Cj0KCQjwla7nBRDxARIsADll0kBrltHLdO8ZIEt53Q6wHMfNeEcgYNFl2Fr-vqybdEyQBpUGBUqJ17YaAuF9EALw_wcB
Thx saw those as well but can’t see how the inner core wire gets fitted/crimped. Maybe I am being dumb!
Strip back the insulation so that the internal conducting wire is long enough to fold back over the insulator and crimp the conductor wire between the connector and the insulation.
Thx I thought that was it, it's a long time since I have played with "old" ignition stuff!! The connectors that Boyer supplied were different and required soldering etc
« Reply #5 on: June 17, 2019, 02:04:06 PM »
For the record got replacement from Boyer at 82p each.
Turns out the Boyer Micro coil pins are 4mm diameter so the standard 7/8mm fittings are not much use and I had no end of trouble finding any 4mm ones anywhere
Offline jon stead
« Reply #6 on: June 17, 2019, 05:40:55 PM »
Good to know and pleased you’re sorted. :-)
