Author Topic: should I use synthetic oil in my 750?  (Read 3750 times)
1884dale
« on: November 06, 2008, 07:01:34 PM »
i have heard not to run synthetic oil in these old bikes (i have a k8)  is that true?
Offline Dave M
Re: should I use synthetic oil in my 750?
« Reply #1 on: November 06, 2008, 08:08:32 PM »
It's too good for them.
They were designed to run on good old 10/40 with frequent oil changes and that's what I use in mine and it's fine even after 30 years.
Whether synthetic would do any damage I don't know but I'm sure there's someone on here who knows...
Dave
Melbourne.
Offline hector2800
« Reply #2 on: November 06, 2008, 11:51:31 PM »
Didn't help my f2 much so I would stick with the 10/40 as recommended
Go on you know you want to
Online Bryanj
« Reply #3 on: November 07, 2008, 03:49:16 AM »
Not worth the cost as you still have to change it every 1500 miles
1884dale
« Reply #4 on: November 07, 2008, 07:53:36 AM »
thanks for the help
Offline Seamus
« Reply #5 on: November 07, 2008, 02:05:14 PM »
What are people generally using. I have some Silkolene 10/40 (possible semi synthetic) for motorcyles, should I use it? or look for something a little less modern like a classic 10/40 from morris or similar.
Seamus
Offline Dave M
« Reply #6 on: November 07, 2008, 03:12:11 PM »
I use anything that's reasonable quality. It gets changed every 1000 to 1500 miles so it's not worth paying out too much.
I think the last lot I bought was Tesco's own and it's been fine!
Dave
Melbourne.
Offline Voxonda
« Reply #7 on: November 07, 2008, 04:30:48 PM »
You can use the full synthetic, but may have the tendency to let the clutch slip! I recommend the 'normal' 10W40 from Castrol or Valvoline, never had any issues with it.
Better sorry for failing than for the lack of trying.
Online Bryanj
« Reply #8 on: November 07, 2008, 05:19:00 PM »
Silkolene Transfleet 10w40 is exactly in the Honda spec if you can get it
« Reply #9 on: November 28, 2008, 07:30:09 PM »
I still use Duckham's 20/50.
Den
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #10 on: February 04, 2009, 05:07:10 PM »
Classic motorcycle mechanics (Feb 2009) did an article on the subject.
The conclusion is that the normal 10w40 oil changed as bike manufactures spec is fine.
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
